D70s PinholeModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
D70s PinholeI created a pinhole "lens" for my camera, here are the results after lots of trial and error. Both 30s at what I estimate to be somewhere between f/60 to f/120. The colour rendition is incredible as is the contrast and gradation between tones - if only I could get it sharper I would sell all my glass
Does anyone know how I can get the camera to take a light measurement for the shutter speed? I imagine it would be the same as using a lens that requires manual setting of the aperture. ISO 200 ISO 1600 http://www.50mmprime.com
D70s | 50 1.4 | 85 1.4 | 18-70 | 70-300 ED | Pinhole | SB800 POTW 24.04.07 - thanks Geoff
Re: D70s Pinhole
Just set your camera to A and it should display the shutter speed, assuming its less than 30s, otherwise it will have Lo displayed...assuming its the same as my D70. What size pinhole did you use? I think you should be able to get it a bit sharper with a very small hole. I did a few pinhole photos with my FE2s years ago and they were reasonably sharp, I just used Aluminium foil over the lens with a very fine pinprick hole. D70, D200, CP5700
Re: D70s Pinhole
The D70 cannot meter without a lens with meter coupled CPU. It will refuse to fire the shutter at A mode if it cannot detect the lens, you need to use it on M mode in this instance.
It defeats the point of calling it a 'pinhole' camera if you use a lens on top. The idea of pinholes are not to have an optical element but very small hole to concentrate light into the film plane (or sensor this case).
maybe, but pinhole *never* "concentrates" the light! A pinhole in front of the lens will give you a much smaller aperture than the lens can ever do, but yes, you do have the advantage of the lens focusing the light still.
In the same vein, using a digital camera sort of defeats the idea too, the original pinhole cameras used emulsion! D70, D200, CP5700
Re: D70s Pinhole
Anyway, back on topic now You may find this interesting to know: http://www.pinhole.org/make/exposure.cfm
Return to Image Reviews and Critiques Who is onlineUsers browsing this forum: No registered users and 35 guests |
