You can vote in the challenge here:http://www.dslrusers.com/viewtopic.php?f=11&t=34917
Going for the all in one picture here.
The themes were:
shadow
metal
anchor
spider web
Shot at f/36, and I still had depth of field issues...
| Weekender 11- PaulmacModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
			Forum rules Please note that image critiquing is a matter of give and take: if you post images for critique, and you then expect to receive criticism, then it is also reasonable, fair and appropriate that, in return, you post your critique of the images of other members here as a matter of courtesy. So please do offer your critique of the images of others; your opinion is important, and will help everyone here enjoy their visit to far greater extent. Also please note that, unless you state something to the contrary, other members might attempt to repost your image with their own post processing applied. We see this as an acceptable form of critique, but should you prefer that others not modify your work, this is perfectly ok, and you should state this, either within your post, or within your signature. Images posted here should conform with the general forum guidelines. Image sizes should not exceed 950 pixels along the largest side (height or width) and typically no more than four images per post or thread. Please also ensure that you have a meaningful location included in your profile. Please refer to the FAQ for details of what "meaningful" is.
		 Weekender 11- PaulmacTalk about late... You can vote in the challenge here:http://www.dslrusers.com/viewtopic.php?f=11&t=34917 Going for the all in one picture here. The themes were: shadow metal anchor spider web Shot at f/36, and I still had depth of field issues...
 Re: Weekender 11- Paulmaclazy bugger ... spent all weekend looking for the right scene so you only had to press the shutter button once eh ?    Shane Life's too short to be sad ! http://bigred4x4.blogspot.com/2008/01/welcome.html http://bigred.redbubble.com
 Re: Weekender 11- PaulmacHa! I had this in mind when I set out with the camera, and I'm glad I got it. However, the fence with the web was about a metre away, and the rails about two behind that, so depth of field was an issue. I even had to wait for the sun to make an appearance!
