Excellent summary for exposure and development
Postby Reschsmooth on Wed Feb 01, 2012 12:48 pm
Our mug is smug
Re: Excellent summary for exposure and development
Postby aim54x on Mon Nov 19, 2012 8:51 am
That is a great link....Thanks Patrick
Postby Matt. K on Mon Nov 19, 2012 12:07 pm
My preferred agitation method was...agitate for the first minute only and then for 10 seconds each minute thereafter. Place the tank down after the 10 sec shake. Why? Gives a lovely edge contrast enhancement where the developer working the highlights is exhausted faster than the developer working the shadow areas.( I think I got that the right way around. Have to think neg/pos). This can be extended by using the waterbath method, or, another way, letting the film sit in the tank after the developer has been dumped and the tank refilled with water. Just let it sit for 10 minutes and reap some enhanced acuity.
Can't believe I still remember this stuff! :D :D
Postby aim54x on Mon Nov 19, 2012 12:21 pm
Matt. K wrote:My preferred agitation method was...agitate for the first minute only and then for 10 seconds each minute thereafter. Place the tank down after the 10 sec shake. Why? Gives a lovely edge contrast enhancement where the developer working the highlights is exhausted faster than the developer working the shadow areas.( I think I got that the right way around. Have to think neg/pos). This can be extended by using the waterbath method, or, another way, letting the film sit in the tank after the developer has been dumped and the tank refilled with water. Just let it sit for 10 minutes and reap some enhanced acuity.
I suspect that it is stuff we will never forget.....I used to use a similar method.....agitate for first minute then 5 sec every minute after.
Postby Reschsmooth on Mon Nov 19, 2012 12:47 pm
For roll film (in tanks), I do the above - 1 min + 10 seconds/minute. I often use water as a stop for 10-15 minutes (as previously recommended by Matt). For sheet film, I tray develop and rotate all the sheets over a minute period - bottom goes to top, timed so that the cycle starts again at a minute. I don't develop more than 8 sheets at a time and prefer not to develop more than 6. I often use just water and move the sheets through the same cycle as otherwise, the sheets stick to each other and I am not sure are full immersed in water to stop development.
Apart from the constat exposure to the chemicals, my main problem with this is that my fingers increase the temp of the different baths. Unfortunately, I am hot blooded, check it and see. I once had a fever of 103!
Our mug is smug
