D80 Shooting SlowModerator: Moderators
D80 Shooting SlowHi all,
My D80 has started shooting slow lately. I've tried everything I can think of including Resetting the D80 Setting all settings the same as another D80 and comparing. New battery New SD card No SD card The time betwwen the shots is much longer than it used to be, it seems as if the Exposure delay mode is on(It's not) Took it into The Nikon place in town, he had NFI. It's done about ~30K frames. For all intensive purposes it's fine but just sloooow, I want to sell it soon but this significantly drops it's value(I wouldnt buy it) Anybody had similar experiences or got any ideas? D80, D90 | SB600 | 18-200 VR | 80 400 VR | 18-135 DX AF-S, 70-300 AF, 50 1.8 | Lotz of other bitz
Re: D80 Shooting Slowfirst things first, stick the body and the lens in MF, whack it in af-c and fire away. make sure its not the AF having problems getting a lock. if its still slow like that and exp delay is off then i have no clue.
Re: D80 Shooting SlowThanks Rooz,
Done all that, still slow? D80, D90 | SB600 | 18-200 VR | 80 400 VR | 18-135 DX AF-S, 70-300 AF, 50 1.8 | Lotz of other bitz
Re: D80 Shooting SlowWhat about the AF-Assist light?
How is that set? In what way does this slowness manifest itself? Please try to be specific here .... g.
Re: D80 Shooting Slowhmmm...cant think what it could be.
maybe try a restore to default to make sure you haven't inadvertently changed a setting somewhere along the line. EM1 l 7.5 l 12-40 l 14 l 17 l 25 l 45 l 60 l 75 l AW1 l V3
Re: D80 Shooting SlowCan you double check your continuous release mode? is it focus priority or shutter priority?
BUT running it in MF should have overridden that. Try turning off the noise reduction completely, if you have not already done so. You have me stumped on this one. Cameron
Re: D80 Shooting SlowI'll try the Noise reduction see how that goes, As for reset the only reset i can find is holding the 2 busstons with the res reset symbol next to them, that seeems to work ok I.E it resets my preferences but does not help.
It's really quite hard to describe what the issue is, but everything about the shotting from the moment I fully press the shutter release button seems slow, mainly the time between 2 shots. for single shots it's not much of a drama but I regularly use it for kneeboarding\wakeboarding shots so it's a pain in the bum! I was thinking somehting like lose spings but have no way of proving that. D80, D90 | SB600 | 18-200 VR | 80 400 VR | 18-135 DX AF-S, 70-300 AF, 50 1.8 | Lotz of other bitz
The two button reset works for some, but not all the settings. THere will be at least one other reset. Check the menus or maybe a hidden button under the camera. Check the manual.
This would be pointing to something in the AF or maybe mirror slap delay ("Exposure Delay mode" on the D200) "
This, on the other hand would indicate HIgh ISO noise reduction or Long Exposure NR I am not familiar with the D80, so can't suggest where these are on your camera, but they are probably there somewhere. Greg
my moneys on this one, the D80 has the "Exposure Delay mode", it is buried at the very bottom of the config menu....plenty of times I have left it on and the next day cursing and trying to figure out whats going on... hopefully thats all it is! gerry's photography journey
Re: D80 Shooting Slowfrom memory there is a factory reset in the setup or custom setup menu.
Re: D80 Shooting SlowCheck what drive mode its in, not the AF mode.
If the camera is in CL of CH(continuos high/Low) the camera will shoot contiuosly and will buffer till it is full and then the camera will slow. If your camera is set to S(single frame) it will not let you take another image till the camera has processed the image, this is made even worse if you shoot RAW. Anyone who shoots with a Fuji DSLR will know that if you shoot on S there is a painful wait between shots. Dont know what menu its in, I dont have a D80, but it will be there. Hope the problem is as simple as this. Mick Nikon D800,D300s X2,F90x,F4e, 18-35AFD,24mm f2, 35mmf2, 50mm f1.8 AFS, 85mm 1.4, 180mm 2.8, SB600, SB800, Elinchrom Quadras.
Re: D80 Shooting SlowHEY GUESS WHAT!!
The Long Exposure NR did it?!?!??!? Go figure? Switch it off and my poort little D80 comes back to life! Thanks everyeone for your help. Still curious why it has started this all of a sudden? I have always had this setting on but never had this prob??(Or so I thought) D80, D90 | SB600 | 18-200 VR | 80 400 VR | 18-135 DX AF-S, 70-300 AF, 50 1.8 | Lotz of other bitz
Re: D80 Shooting SlowI thought that long exposure NR took a second image identical to the first with the shutter closed to map the noise or something like that. It would certainly slow down your continuous shots.
Nikon D7000
That's pretty much spot on. That means your 1/250s exposure will take 1/125s. Your 30Sec exposure will take 60 sec. Greg
Who is onlineUsers browsing this forum: No registered users and 44 guests |
