Flash suggestionsModerator: Moderators
Flash suggestionsI dropped my SB600 last Saturday night about half a metre onto a hard surface. No exterior damage but it is just not working at all...no noises, lights or action in any way. I have replaced batteries and done all the usual non intrusive stuff including a few good shakes and a terminal clean but alas, not a squeak out of it. This was a great little flash.
I am interested in your opinions as to my next move. I use a D200 and use flash quite a bit. Should I try to get it repaired? (Nearly 4 yrs old and quite a bit of use) Should I get an identical replacement ie another SB600? (Much cheaper now in HK than my original but technology is moving on) Should I upgrade to the new SB900? ($649 from HK...is this a better option?) Any ideas based on your knowledge & experience would be greatly appreciated. Kind regards Nikon & Olympus
Re: Flash suggestionsPeter,
When you shake it, does it make any noises? Is the tube still in one piece? I would say that it's toast, and given the price of a replacement 600, repairs would probably not be a viable alternative. Does the 600 meet your needs? Will it continue to meet your needs into the next, say, three years? Consider potential future camera upgrades - how much longer do you anticipate using the D200, and what would your upgrade path be? If that's a yes, then just replace it. Otherwise, upgrade. g.
Re: Flash suggestionsI believe it is not uncommon for an SB-600 not to survive after a drop. I'm pretty sure another member had the same experience in the last 12 months and at the time a Google search found quite a few matches for similar issues - not a scientific sample by any means.
Re: Flash suggestionsThanks for your input.
Sad that such a good flash breaks so easily. Maybe a good warning to others. In short Gary, it is officially toast. ATJ, your non quantitative analysis about the breakability of SB600 is good enough for me. I think the prospect of a SB900 is looking good at the moment. A bit more power and a few more flashing lights never did any harm. I think the D200 will last me long enough (providing I don't drop it also) to skip a model and go for the D400 or whatever is the heaviest equivalent of a DX camera in about a year's time. Should fit on that quite well. By that time I will also have worked out how to use it. Cheers. Peter Mc Nikon & Olympus
Re: Flash suggestionsNo flashgun that I know of will survive a drop onto a hard surface. I would suggest send it to Nikon for a repair quote. If it costs under $200 then perhaps repair is an option. Usually.....and in my experience...when Nikon fix something they do a good job and the work is guaranteed. The item usually comes back as good as new. By the way...I have a small Metz hot-shoe mounted flashgun that is over 30 years old and still giving sterling service! So even if you plan on buying a new flash-gun down the track it's still nice to have an extra. 2 guns = small studio flash setup.
Re: Flash suggestionsYour repair will be in the region of $200....BigGerry dropped my SB-600 when I lent it to him and then he got it repaired (to keep for himself, replacing mine with another bought from HK) with a bill of around that price. For that price you can get yourself a new Nissin Di622 from HK (which does pretty much everything a SB-600 does other than CLS...but does have a built in optical trigger)
I would say... if you can afford it, get the SB-900, or even wait a few months to see if the SB-700 surfaces (only if you dont need the flash urgently). Cameron
ta for that Cam, I was trying to keep that quiet - no chance of lending that 70-200 eh?
was that from Nikon? I did fair amount of research about these fragile units, essentially if you drop it you will most likely bust the xeon tube, which is pretty abviously cause you can hear rattling around or its the inductor, if it ain't one of these then its probably well and truly fried, but at only 0.5m I would be surprised. The actual parts are dirt cheap and can be ordered from Nikon, the hard part is gettign it all put back together once its fixed.. Repair from Nikon should not exceed 200 bucks if it is indeed repairable - thats about the maximum pain threshold for that unit. gerry's photography journey
Re: Flash suggestionsSorry Gerry! When do want that 70-200? Call me to organise.
just stirring mate! I don't think i would know what to do with teh AF on the 70-200, would like all my christmas had come at once gerry's photography journey
Go for it! I replaced my SB600 with an SB900. Never mind the power. The controls work the way they all should. i.e. dead easy to set. Being able to use it as a master is a real boon too. Even if you don't have extra flashes at the moment, this is a great way to go. YOu can always borrow extra flashes at need. Only downside is that the new radio poppers don't work with them, but they are vapourware anyway (in this country at least!) Greg
Re: Flash suggestionsI must be lucky. My SB-600 has hit the dirt several times, and once fell into a river, and is still going strong.
Re: Flash suggestionspeter, unless you need the power and throw of the sb900 i'd be looking at an sb600 for sure. depends what you want out of your flash, if its simple hotshoe mount flash which you can bounce and swivel around then for me, save the money.
Re: Flash suggestionsdarklightphotography
Fell into a river and still works! Man...you are lucky! The gods smiled on you that day. Regards
Who is onlineUsers browsing this forum: No registered users and 11 guests |
