D7000 Firmware Update 1.02
Postby biggerry on Wed Apr 27, 2011 10:26 pm
Copied from the aussie nikon site - cheers to ray for the heads up.
# Noise reduction processing is now performed with shutter speeds slower than 1 s (previously 8 s) when On is selected for Long Exp. NR in order to reduce the bright spots that occur with shooting of still images at slow shutter speeds.
# An issue that prevented the opening of movies recorded with the D7000 in certain movie editing software applications has been resolved.
# When the camera was connected to a television via the A/V cable and a movie was played back, playback was normal the first time but when the movie was played two or more times, the sound was played back at extremely low volume and seemed to play intermittently. This issue has been resolved.
# When white balance for RAW images created using the camera’s image overlay function was fine tuned with Capture NX 2 or ViewNX 2, the images acquired a magenta cast. This issue has been resolved.
# An issue that caused 0.00” to be displayed for heading information when the GP-1 GPS unit was connected to the camera has been resolved so that ---.-- is now displayed.
# When Viewfinder virtual horizon was the role assigned to the Fn button or the preview button and the applicable button was pressed, errors in the virtual horizon indicator were displayed. This issue has been resolved.
# The following errors in Help displays have been resolved.
* “Maximum sensitivity” help was displayed for shooting menu>ISO sensitivity settings>On or Off help.
* German help displayed “Select focus priority for AF-S mode.” for Custom Settings>a1: AF-C priority selection help .
http://nikonrumors.com/2011/04/24/nikon-d7000-firmware-update-1-02-is-now-official.aspx?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+NikonRumors+%28NikonRumors.com%29
Re: D7000 Firmware Update 1.02
Postby Remorhaz on Thu Apr 28, 2011 7:59 am
Yes but have you applied it yet :)
Postby biggerry on Thu Apr 28, 2011 8:44 am
Yep, takes two minutes.
Postby ATJ on Thu Apr 28, 2011 9:42 am
Postby biggerry on Thu Apr 28, 2011 2:38 pm
ATJ wrote:Here are the links to the firmware updates:
I downloaded the firmware from the aussie nikon site, I assume there would be no difference between countries in this regard.
Postby ATJ on Thu Apr 28, 2011 3:34 pm
Those links are "from the Aussie site". nikon.com.au points off to nikonasia-en.custhelp.com for support.
Postby biggerry on Thu Apr 28, 2011 3:55 pm
:up:
Return to Nikon
Users browsing this forum: No registered users and 21 guests
