Eclipse or Isopropyl alcohol?Moderator: Moderators
Eclipse or Isopropyl alcohol?Just noticed this thread in DPReview:
http://forums.dpreview.com/forums/read. ... e=10000719 And the comment was made that isopropyl alcohol was less corrosive than methanol. I know that we used to use isopropyl to clean fax image sensors but don't know about this application. Does anyone know? If this was so it would make importing the pads easy and just mix with iso when it gets here. Any thoughts?
Yes, it will work just as well - however I believe the issue is purity. All alcohol is hydroscopic, and many forms of it are deliberately mixed with water to reduce its evaporation rate. Other chemicals may also be present for one reason or another (eg. I know LPG is odourless but they add a stinking odour to all supplies so people can detect leaks).
I use isopropyl from my local chemist. That way you can get it in a pure enough form. --
I rang Lube Mobile today. Imagine my disappointment when I found out they were mobile mechanics.
Yes I never was quite convinced that it's worth paying a hundred dollars or more for a paddlepop stick worth $4. I just use a microfibre cleaning cloth (lint free) to clean the CCD. One drop of isopropyl is more than enough. --
I really don't know why some people on dpreview carry on about cleaning the sensor as being akin to neurosurgery. The AA filter is made from lithium niobate ferchrissake! It ain't THAT delicate Yes it works out quite well, and I clean around once a week. Most times I won't use any fluid, just breathe on the filter, and give it a rub with the cloth. Heresy? The earth is flat, friends.... --
If you're going to clean it weekly, why not just use an oily rag ?
I do - only use AGIP synthetic. That way, you can keep shooting up to 7000RPM before it fills the frame buffer. --
AGIP Synthetic? Should be good for at least 15000RPM. Doesn't your CF card have double overhead chrome plated hydraulic buffers? g.
No, it has the desmodronic valve system, to stop electron valve bounce on the data bus. Geez, I really wish you guys would keep up. --
I tried to hail the data bus one time, but the driver wouldn't stop. He was in the wrong timing loop it seemd. g.
That's because you used an outdated driver. You need to update the driver in order for the system to work properly. The latest version is 6.1.0. --
Who is onlineUsers browsing this forum: No registered users and 54 guests |
