Bit of a tripod question
Postby DJT on Mon May 19, 2008 9:24 pm
Evening all.
Hopefully this belongs in this section
Want to order a tripod tomorrow. I've decided on the manfrotto 190XPRO, because that's all that fits my budget & weight requirements. Looked at Giotto, Benro, Slik & Benbo & Gitzo - all either too expensive or heavy.
My question tonight is. Are there any real benefits of a ball head over a 3 way. My heaviest lens in my Sigma 70-200 f/2.8. Unless I win lotto I will not be getting anything heavier than this in the near future.
So looking at either manfrotto's 804RC2 (pan /tilt) or the 486RC2 (ball).
Appreciate any comments - maybe I have overlooked something
DJT
Re: Bit of a tripod question
Postby aim54x on Mon May 19, 2008 9:41 pm
Do you mean the 488RC2?
The 190 series tripods have a weight rating of 5kgs so the 804RC2 pan-tilt with a 4kg rating is a good match, hence it is kitted together. The 488RC2 has a weight rating of 8kg, so it will support a lot more than the 190 legs, so it is not recommended by Manfrotto to go this way. The 486RC2 is a ultra compact ball head with a 6kg weight limit. All of these heads would be a good match to the legs, but will result in a tripod with a 4-5kg limit, limited by the legs. Buying a 488RC2 will mean your head will be useful if you buy bigger lenses or upgrade your camera body.
On the topic of pan-tilt vs ball heads, pan-tilt provides you with ease of use with the expense of compactness. Ball heads are much more compact but tend to be a little harder to get used to. I would probably recommend the ball head due to the compactness, especially if you plan to take your tripod around a lot.
Personally I have a trigger grip head (322RC2) on my main tripod, a built in ball (on the 714B, which I loathe due to the lack of a quick release) and a pan-tilt (on the crappy Optex).
Hope this helps, and not too many people flame on me for this.
Check out the tripod configurator at http://www.manfrotto.com/Jahia/news/site/manfrotto/pid/16203/lang/en
Postby DJT on Mon May 19, 2008 10:01 pm
thanks 486 is the go then
DJT
Postby robert on Tue May 20, 2008 10:49 am
I use a 486 and have been happy for years.
The only drawback is no panning lock- its all by the one lever so the camera moves on its ball as well as pan. Now I'm into panoramas and stiching I want another head as a result.
Consider the Giottos range- Discount Digital has them dead cheap. I'm contemplating the 1303 before I save the $$$ for a Really Right stuff head.
Robert
Robert
robert
Postby aim54x on Tue May 20, 2008 6:16 pm
robert wrote:I use a 486 and have been happy for years.
Good point! Maybe have another look at the 488RC2, it has a pan lock.
Postby DJT on Tue May 20, 2008 11:31 pm
I've decided on the Giotto MH1001 ball head at the moment.
DJT
Postby potato1 on Mon May 26, 2008 6:18 pm
I've had a look at this head, how good is it under weight (say 3kg or so)? Does it tend to slip even when fully locked?
potato1
Postby aim54x on Mon May 26, 2008 7:20 pm
Well I have never actually had a chance to road test one of these heads, but I can say that it has a weight limit of 8kg, which is 3kg more than my 322RC head, so I would suspect that you will have not slipping problems. I routinely put my D300+MB-D10+24-70mm f/2.8 on my 322RC2 with no problems. I had this set up with an extra SB-800 on that head the other night, if the 5kg rated head can deal with 3.5-4kg load then I would assume that the 488RC2 will have no probs. I have played with one in shop, and when locked I cant feel any movement when I pull/push on it.
http://www.manfrotto.com/Jahia/site/manfrotto/cache/bypass/pid/2306?livid=80&lsf=80&child=2 488RC2
http://www.manfrotto.com/Jahia/site/manfrotto/cache/bypass/pid/2319?livid=80&lsf=80&child=2 322RC2
Users browsing this forum: Majestic-12 [Bot] and 18 guests
