Nikkor 50mm 1.8G issues
Postby Raskill on Mon Jun 03, 2013 6:55 pm
Ahoy folks,
Long time, no post.
Just have run into an interesting issue with my trusty 50mm 1.8G.
I recently bought a couple of D600 bodies, and went for a walk about with one of them mounting my vaunted 50mm G.
Getting back I found that high contrast areas produced purple fringes. Terribly so. So, I tried it on the other body, and it did it on there also.
So, panicking I mounted a 70-200 and tested each body, nil issues. Nor with any other lens I tried.
Is it possible that the lens doesn't focus all the light properly on the new bodies? Has anyone ever had anything similar with any setup?
Incidentally, everything else works fine on the bodies, and I am amazed at the images they produce.
http://www.awbphotos.com.au
Raskill
Re: Nikkor 50mm 1.8G issues
Postby Matt. K on Mon Jun 03, 2013 7:13 pm
Are the images sharp? IE: is the camera focusing the lens correctly? Also...is there a filter on the lens? Lastlt, can you post a couple of examples.
Postby chrisk on Mon Jun 03, 2013 9:18 pm
At what apertures ?
chrisk
Postby gstark on Tue Jun 04, 2013 10:27 am
And of what subjects?
Posting a few examples is the best idea.
Users browsing this forum: No registered users and 17 guests
