Converting to B&W... the Greg Gorman way....Moderators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Converting to B&W... the Greg Gorman way....Okay people... here's a quick run down on how to convert to black and white (with photoshop) the Greg Gorman way. This technique is used (and created) by Greg Gorman http://www.gormanphotography.com/gorman.html , who is a primary photographer to the stars in hollywood etc etc .... Hope you find it useful...
Open an image in Photoshop, and convert it to 16-bit if you can afford the disk and memory space Convert the image to LAB color, using Image » Mode » Lab In the Channel palette, select the Lightness channel, then convert the image to grayscale using Image » Mode » Grayscale Cmd+Click (MacOS) or Ctrl+Click (Windows) the thumbnail in the Channels palette to load a selection, then choose Inverse from the Select menu With the selection still active, convert the image to RGB color, using Image » Mode » RGB With the selection still active, create a Solid Color Adjustment layer, and fill it with whatever color you wish, preferably a rich, dark color Adjust the opacity of the Solid Color adjustment layer and add a Levels or Curves adjustment layer to bump the contrast as needed Tweak the color of the Solid Color adjustment layer to control various sepia tone looks. This technique produces wonderfully rich black and white photos. I've turned the above into a simple action. I recommend you do so as well. Last edited by xerubus on Wed Jan 12, 2005 11:43 am, edited 1 time in total.
http://www.markcrossphotography.com - A camera, glass, and some light.
xerubus
Thanks for that. It's a technique I haven't seen before. I'll give it a whirl tonight. As you are probably aware there are any number of different ways to get to B&W. I've yet to pin the absolute best way. Regards
matt... my pleasure....
i'm the same way... been through various techniques depending on the shot.... at the moment i switch between the above conversion and the carr b&w conversion..... http://www.markcrossphotography.com - A camera, glass, and some light.
jon, aside from the process xerubus has outlined above (thanks xerubus, I'm looking forward to giving that a go), you can also have fun splitting your image into channels (in Photoshop and probably other programs) - you get quite different looking BW images from each of the R G & B channels.
Greg - - - - D200 etc
Thanks xerubus.
All ways looking for new approaches to anything concerning PS I’ll have a play with that latter, "If I ever get through the new posts on this forum!!!!!! " Cheers Ray >> All of us could take a lesson from the weather. It pays no attention to criticism<<
Robb Carr is the photoshop guy that works for greg gorman.... you can grab the action at the following: http://www.designbyfire.com/pdfs/Carr_B&W.atn cheers http://www.markcrossphotography.com - A camera, glass, and some light.
Who is onlineUsers browsing this forum: No registered users and 26 guests |
