by Matt. K on Sun Feb 06, 2005 9:35 pm
To get that tricky red rose glowing against a black and white background effect......Open your image and go to the layers pallet (F7). Click on the ying yang looking circle at the bottom of the layers pallet and choose hue/saturation. Drag the saturation slider all the way to the left. Now choose a paintbrush and with black as your foreground colour paint on the image. To remove the colour set white as the foreground colour. Play with the opacity slider in the layers pallet when you are finished. Flatten layer when completed. Neat.
by beej on Sun Feb 06, 2005 11:58 pm
Great tip Matt.
I dug up a boring shot to play with. Works a treat.
- beej
beej
- Member
by Matt. K on Mon Feb 07, 2005 8:25 am
beej
Quick work!
by Killakoala on Mon Feb 07, 2005 11:01 am
Steve. |D700| D2H | F5 | 70-200VR | 85 1.4 | 50 1.4 | 28-70 | 10.5 | 12-24 | SB800 |Website-> http://www.stevekilburn.comLeeds United for promotion in 2014 - Hurrah!!!
by stubbsy on Mon Feb 07, 2005 12:44 pm
Thanks for sharing this. I'm building up quite a file of tips from you.
- Moderator
by stubbsy on Mon Feb 07, 2005 12:46 pm
Love the shot of Thaddeus(?). I'm guessing the tripod is useless with a bend in it like that
- Moderator
by ajo43 on Mon Feb 07, 2005 12:59 pm
Matt
I've noticed that you've done a vew very helpful posts on PP (contrast mask etc). I wonder if some day you might consider conolidating them all into a tutorial??
I reckon we'd all benefit greatly.
Jonesy
ajo43
- Member
by phillipb on Mon Feb 07, 2005 2:24 pm
Yep! This tip is a keeper.
Great way of minimising distracting backgrounds.
__________ Phillip
**Nikon D7000**
phillipb
by birddog114 on Mon Feb 07, 2005 2:30 pm
phillipb wrote:Yep! This tip is a keeper. Great way of minimising distracting backgrounds.
Oh no! I see it as CANON
birddog114
by phillipb on Mon Feb 07, 2005 2:36 pm
That's original colour birdy, It's the strap that came with my N80
May be Matt can add part 2 to the tutorial, "How to turn canon colours into nikon colours"
__________ Phillip
**Nikon D7000**
phillipb
by birddog114 on Mon Feb 07, 2005 2:44 pm
phillipb wrote:That's original colour birdy, It's the strap that came with my N80 May be Matt can add part 2 to the tutorial, "How to turn canon colours into nikon colours"
Yeah! that's what I meant!
birddog114
by phillipb on Mon Feb 07, 2005 2:48 pm
OK Birdy, just for you.
Used the same method except instead of saturation I changed the Hue
__________ Phillip
**Nikon D7000**
phillipb
by birddog114 on Mon Feb 07, 2005 3:06 pm
phillipb wrote:OK Birdy, just for you. Used the same method except instead of saturation I changed the Hue
Now It's better and nice! my colour.
birddog114
by Marty on Mon Feb 07, 2005 7:47 pm
Thanks Matt,
that is a quick way to get the result.
Makes life much easier.
Marty
What does that button do....??
Marty
- Member
by tsanglabs on Mon Feb 07, 2005 8:00 pm
Thanks for the tip Matt, just tested it out and it is a very fast method and works a treat .
tsanglabs
- Member
by MATT on Mon Feb 07, 2005 10:46 pm
THanks for the tip that saves a lot of mucking around.
MATT
MATT
by christiand on Mon Feb 07, 2005 10:52 pm
I've bookmarked this tip.
Thanks a lot.
CD
christiand
by sirhc55 on Mon Feb 07, 2005 10:55 pm
Or with replace colour command
- Key Member
by Neeper on Tue Feb 08, 2005 8:00 am
How do you do the edges?? Do you guys zoom in?
Neeper
- Member
by Paul on Tue Feb 08, 2005 8:15 am
Thanks for the tip,
Nikon F80D, FM2n RRS BH-55, 055XPROB Smugmug
Paul
by phillipb on Tue Feb 08, 2005 8:32 am
Neeper wrote:How do you do the edges?? Do you guys zoom in?
Yep, zoom in to 100% and use a very small brush for the detail work.
__________ Phillip
**Nikon D7000**
phillipb
by beej on Tue Feb 08, 2005 8:39 am
Neeper,
I'm not sure if this is the best way (i'm a noob), but for the edges i just use the magnetic lasso tool and go right around the edge, once the object is selected i then brush "in" the colour using Matt's tip.
- beej
beej
- Member
Return to Tips and tricks
