surenj wrote:Looks like an interesting body. This might fit nicely in the void between 50D and 7D. The high ISO performance looks ok.
Doctor wrote:Is it meant to fit between those two? i thought it was still below the 50d, it is at least physical size wise etc
surenj wrote:Doctor wrote:Is it meant to fit between those two? i thought it was still below the 50d, it is at least physical size wise etc
You make a valid point! my Sony, I think it's between the 500D (perhaps to be discontinued) and 50D. However some of the features trump the 50D!
Doctor wrote:surenj wrote:Doctor wrote:Is it meant to fit between those two? i thought it was still below the 50d, it is at least physical size wise etc
I think it effectively replaces the 450d, pushing the 500d down a peg and wedging itself between the 50d and the 500d.
Its the usual game of leapfrog though, the lower end cameras always end up catching the higher up ones and trumping them on some features... The 550d still couldnt replace my 50d though, there are instances when the higher FPS are handy, and the physical size difference is too much, my hands used to crap on the 400d, i dont think the 550 could be a much bigger improvement
Nnnnsic wrote:The way Canon described it to me was that there's now a 1000D, 450D, 500D, and 550D in the beginner line-up.
DaveB wrote:I think it's just to clear their stock levels of the old model. I doubt the 450D is still being made!
photomarcs wrote:6. You can't really do much in Custom Fn in the 550D, you also dont have a rear AF ON button ( I know you probably wont like that DaveB, the AF ON technique works well)
DaveB wrote:photomarcs wrote:6. You can't really do much in Custom Fn in the 550D, you also dont have a rear AF ON button ( I know you probably wont like that DaveB, the AF ON technique works well)
Not a problem in this case. Like every Canon DSLR other than the 300D, you can move the AF-ON function from the shutter to the '*' button. In this case via C.Fn IV-9 (set to 3).
It was only in the 40D that they introduced a separate AF-ON button (and you still need to configure those cameras with that button to take the AF away from the shutter button). Even in 2000 my D30 had focus tied to the '*' button!
Users browsing this forum: No registered users and 0 guests
