Nikon Capture 4.1 crashes Dell Insprion 9300 laptop
Postby swanson on Wed May 11, 2005 2:58 pm
Nikon Capture 4.1.x crashes my new laptop Dell Insprion 9300 (Window XP and SP2) and many other new PCs. :cry: :cry: :cry:
So beware of the new PC upgrade!
swanson
Re: Nikon Capture 4.1 crashes Dell Insprion 9300 laptop
Postby birddog114 on Wed May 11, 2005 3:01 pm
swanson wrote:Nikon Capture 4.1.x crashes my new laptop Dell Insprion 9300 (Window XP and SP2) and many other new PCs. :cry: :cry: :cry:
That's happenned with one of our member: pluckaduck, he got the same new model Insp. 9300. He brought over the meet and no one can help.
Poor Dell guys! but not other PCs as far as I known.
I run XPP with SP2 and all worked well on the P4 PCs
birddog114
Postby stubbsy on Wed May 11, 2005 3:02 pm
That's strange
I have a brand new Pentium 4 PC and it works fine. When you say it crashes, how so?
Postby gstark on Wed May 11, 2005 3:07 pm
I would remove SP2, and get rid of the Dell.
In no particular order.
More seriously, did you reboot after installing?
How is your SP2 Firewall (mis)configured?
Disable that, and see what happens.
My guess is that NC is behaving badly in the way that it's trying to call home when you load it. The SP2 Firewall is probably rejecting the attempts to call home, and NC hasn't got a clue how to deal with that, hence it goes down in a screaming heap.
Postby Onyx on Wed May 11, 2005 3:27 pm
Not just Dell - Glen remarked he couldn't get NC41 to run on his Asus lappy either. I think it's more to do with the new northbridge chipset of the newer Pentium-M's.
Onyx
Postby Glen on Wed May 11, 2005 3:32 pm
Yes my Asus wont run any Capture below 4.21, wont even boot the program, just crashes.
Postby birddog114 on Wed May 11, 2005 3:35 pm
Onyx wrote:Not just Dell - Glen remarked he couldn't get NC41 to run on his Asus lappy either. I think it's more to do with the new northbridge chipset of the newer Pentium-M's.
Glen's problem is difference, he used the NC 4.1xxx to install and the old code did not work and he had to start install the NC 4.0 then used the u/g path.
With pluckaduck's "Hell Insp. 9300" we uninstalled NC and started from 4.0 and it crashed as soon as we attempted to click to NC icon.
birddog114
Postby birddog114 on Wed May 11, 2005 3:37 pm
Glen wrote:Yes my Asus wont run any Capture below 4.21, wont even boot the program, just crashes.
I thought you already solved the problems with NC 4.0.
Sorry, I withdraw my earlier post.
birddog114
Postby Glen on Wed May 11, 2005 3:39 pm
That is what mine does Birddy. NC crashes when I touch the NC icon on version 4 and 4.1 (or is it 4.2). If I upgrade them without using inbetween to 4.21 it will open but requires a new key to activate which I don't have. Seems the old software is incompatible with the new chipset.
Postby birddog114 on Wed May 11, 2005 3:40 pm
Glen wrote:That is what mine does Birddy. NC crashes when I touch the NC icon on version 4 and 4.1 (or is it 4.2). If I upgrade them without using inbetween to 4.21 it will open but requires a new key to activate which I don't have. Seems the old software is incompatible with the new chipset.
Yes, it's! where's your "GOLD KEY" ? :lol:
birddog114
Postby Glen on Wed May 11, 2005 3:46 pm
I am sure with patience one day I will see a gold key :wink:
Postby gstark on Wed May 11, 2005 4:52 pm
I'm not sure what chipset I've got on my ASUS, but it's a centrino 1.7, freshlyminted in July last; it's had no problems running any version of NC thus far.
Postby Glen on Wed May 11, 2005 4:59 pm
Mine is the 740 chipset, 1.7ghz
this is the model no W5GA740DD58PGW
and an info page http://www.synnex.com.au/Default.aspx?t ... genumber=0
Postby gstark on Wed May 11, 2005 6:03 pm
Mine seems to be listed as M6SNe735DD58PG, which is also a Centrino 1.7, but the 735 CPU, rather than the 740. I don't believe that there would be any functional differences between the 735 and 740; the Asus catalogue lists the M715-770 as being applicable to my model, and the M730-770 for yours.
Where there may be a difference is in the supporting chipset - mine uses the Intel 855PM while yours uses the 915GM
What does the Hell Insprion 9300 use?
Postby Onyx on Wed May 11, 2005 6:17 pm
gstark wrote:Where there may be a difference is in the supporting chipset - mine uses the Intel 855PM while yours uses the 915GM
My guess is that it's the 915 - and that's the chipset that's somehow incompatible with earlier NC versions.
Onyx
Postby Glen on Wed May 11, 2005 6:17 pm
Mine was basically empty when I tried to install it, so I doubt conflicting software. The 4.21 opened no problem so I am assuming a hardware incompatibility. Not a huge concern as my screen is 12" so tend to use the desktop for downloading but still have Nikon View on the lappy so I can download in the field. One day I will find a golden key :wink:
Postby MCWB on Wed May 11, 2005 6:52 pm
Onyx wrote:My guess is that it's the 915 - and that's the chipset that's somehow incompatible with earlier NC versions.
I think the 9300s are all Dothan-cored CPUs aren't they, rather than the Banias-cored CPUs in Gary and Glen's laptops, so it's common to both... :( 4.2.1 works ok though Glen? Does 4.2.1 work ok on the 9300? Bugger, was considering a centrino-based notebook for PP on the go!
MCWB
Postby Glen on Wed May 11, 2005 7:02 pm
Trent, I uninstalled 4.21 as I didn't want thirty days of sucess followed by failure when no key arrived. Also was installing MS Office and finance software and didn't want it confusing anything. It seemed to go ok, but will need a golden key to get past thirty days (which has nothing to do with compatibility with my chipset)
Postby gstark on Wed May 11, 2005 8:32 pm
No, mine is a Dothan.
Postby Glen on Wed May 11, 2005 8:49 pm
I have no idea if mine is Dothan or Banias, in fact I thought it was Sonoma or maybe that is just an area in California?
Postby birddog114 on Wed May 11, 2005 8:51 pm
Glen wrote:I have no idea if mine is Dothan or Banias, in fact I thought it was Sonoma or maybe that is just an area in California?
Glen,
Yours is the Dothan and/ uses the DDR2 memory same as the "Hel Insp 9300".
birddog114
Postby Glen on Wed May 11, 2005 8:56 pm
Thanks Thanh, I would have never worked that out :wink:
Postby Onyx on Wed May 11, 2005 9:20 pm
Glen, yours is a Sonoma. If it has a 915 northbridge, and supports DDR2 - it's a Sonoma. The Banias was the first generation labelled "Centrino", and Dothan was the mid-life refresh/upgrade that hardly added any extra features other than minor speed increases. Architectually they're very similar, which is more than can be said for the Dothan to Sonoma transition (SATA HD support, DDR2, etc.)
Onyx
Postby Glen on Wed May 11, 2005 9:35 pm
Onyx, you are right. I live about 2 kilometres from Northbridge and 915 sounds like the bus number which goes there. I think I am miles out of my depth in this thread and will just wait till I find a golden key :wink:
Postby birddog114 on Wed May 11, 2005 10:05 pm
Glen wrote:Onyx, you are right. I live about 2 kilometres from Northbridge and 915 sounds like the bus number which goes there. I think I am miles out of my depth in this thread and will just wait till I find a golden key :wink:
Glen,
Don't worry too much, I might have a golden key soon.
birddog114
Postby Glen on Wed May 11, 2005 10:09 pm
Thanks Birddy, no problem if one doesn't turn up, but a nice bonus if it does. Will also save me trying to guess what is inside this thin white package called a notebook :wink:
Postby gstark on Thu May 12, 2005 2:25 am
Glen,
Maybe a Golden Retriever might help?
Postby Glen on Thu May 12, 2005 9:20 am
gstark wrote:[
:lol: :lol:
Postby Oneputt on Thu May 12, 2005 9:38 am
Glen you reckon you are out of your depth? I don't think that these guys speak English :wink:
Oneputt
Postby stubbsy on Thu May 12, 2005 11:02 am
Oneputt wrote:Glen you reckon you are out of your depth? I don't think that these guys speak English :wink:
Hell I thought Northbridge was in Perth and Glen says it's near him in Sydney :lol:
Postby Glen on Thu May 12, 2005 11:22 am
Stubbsy, thats the nightclub Northbridge, I live near the retirement Northbridge where Bob Hawke lives (maybe he likes living about 4 kms from John Howard so he can drop in and have afternoon tea?)
One of the great thing about this board is where else can you get a busload of computer gurus to give an opinion on your computer and actually want to help you fix it?
ps Stubbsy, thank you very much for your tip on straightening horizons in Capture, used it last night before a few prints out with the new R1800. I almost feel qualified to give PP lessons now, I can crop, change levels, sharpen and straighten horizons!!
Postby gstark on Thu May 12, 2005 11:25 am
Now you just need to remember to feed the paper in straight. :)
Now you just need to stay sober enough to feed the paper in straight. :)
Postby Glen on Thu May 12, 2005 11:27 am
Gary, that was how I straightened horizons in the past, just tilted the paper feed :lol:
Postby gstark on Thu May 12, 2005 11:44 am
It's actually easier to just tilt the printer.
But you need to be very careful with water shots, 'cos if you tilt the printer too far forward, you'll get your shoes wet from the spillage.
Postby MCWB on Thu May 12, 2005 1:14 pm
You can just tilt it over the spa, where you usually take the finished product anyway? :lol:
MCWB
Postby kaufuu on Thu May 12, 2005 2:54 pm
Hi, Swanson, Glen and those who might have NC4.1 crashes, try the
following which worked for me in Windows XP :
go to
control panel
|Regional and Language Options
|Advanced
under "Language for non-unicode programs"
set it to "English (Australia)" if it is some non-english chosen.
click apply / ok
reboot the system.
hope that will help.
kaufuu
Postby birddog114 on Thu May 12, 2005 2:55 pm
kaufuu wrote:Hi, Swanson, Glen and those who might have NC4.1 crashes, try the
go to
control panel
|Advanced
click apply / ok
reboot the system.
Thanks, good thoughts!
birddog114
Postby Glen on Thu May 12, 2005 3:11 pm
Thanks Kaafu, will try it and let all know
Postby kaufuu on Sat May 14, 2005 11:11 am
Hi Glen, since you didn't say it worked, i assume that was not.
the solution i gave the other day just came off my memory at that
time, its been a while since i installed the NC4 and sp2, last night i
sat down and checked again, there are two other things that
need to be set which i assumed they were set by default, or i
might have changed them the moment i upgraded sp2, i always hate
those additional restrctions.
anyway, IN ADDITON TO the last post, check and set the
followings:
1. control panel | system | Advanced
under "Performance" click "Settings" button
go to "Data Execution Prevention"
make sure the "Turn on DEP for essential Windows program and
services only" option is chosen
click Apply/ok if change has made
2. control panel | system | Advanced
under "Startup and Recovery" click "Settings" button
under "Default operating system"
inside the box, the line should be like "Microsoft Windowns XP ...
...../NoExecute=OptIn"
if it is /Execute, then change it to /NoExecute=OptIn.
you can use the "Edit" button 3 lines down to edit the file
boot.ini which contains that statement.
Reboot the system.
be sure to copy down the original option or statement in case you
have to go back.
those changes are at the kernel level, so becareful, and do it
at your own risk.
hope it helps this time.
have a nice day.
kaufuu
kaufuu
Postby MattC on Sat May 14, 2005 4:28 pm
The problem is probably a simple software conflict - good ol' NC. My tip would be to have a dig through the startup folder and remove anything that is not absolutely essential (I only have Colorvision Startup here - all else is gone), then have a dig through the hidden startup (msconfig.exe) items and again, disable everthing that is non-essential (if in doubt Google it). Next stop for me would be services. Reconfigure unneccessary services to either disabled or manual start - do not use msconfig for this. There is a good chance that cleaning all of the rubbish out will allow NC to run.
Dell installs a lot of crap on their systems which is for the most part unnecessary. If you have a Dell printer, there is one of those startup items which may cause problems with NC. Dell Quickstart gave me a hard time with conflicts until I removed it completely - this one is not required anyway. Most of their network utilities are simply not needed. The list goes on.
There is so much software these days that insists on inserting itself into the startup folders that simply does not need to be there. Clean 'em out and run with a leaner, faster computer.
If it is DEP, disable it by changing ...NoExecute=OptIn to ...NoExecute=AlwaysOff in boot.ini. I doubt that is the problem though (that problem seems to be limited to AMD64 with hardware DEP) unless Intel has added hardware DEP to the latest P-M.
Matt
MattC
Postby Glen on Sat May 14, 2005 5:20 pm
Hi Kaufuu,
I tried the first and it didn't work, didn't repley because didn't want to make a big deal of it. Tried the DEP routine the first time, didn't work then either. Someone has sent me a piece of gold, will let people know if things are sucessful. If they are best to pm me in future on this.
Postby swanson on Wed Jun 15, 2005 9:55 am
Hi All,
At last, NC is up and running on my laptop:D
- Changes "/NoExecute=OptIn" to "/NoExecute=AlwaysOff". and re-boot.
Thanks for your rely.
Swanson
swanson
Postby ipv6ready on Wed Jun 15, 2005 10:48 am
Just a quick thought, after I loaded NC 4.2.1 last night
You have to be logged in as "Administrator" account to install NC. or it won't complete setup.
Also I have a laptop and a PC.
On the PC I had NC trial plus code and tried to upgrade -> failed?
Laptop I installed from the “upgrade package” clean (no older NC on it) and it installed.
I don't know if this helps but one other thing.
Try loading into safe mode (press F5 or F8 a few times as the windows boots up) under administrator and try to install.
Safe mode means very few third-party driver or extra software other than essential list executed in start-up. PS.... I have never tried installing software under "safe mode" maybe others can elaborate if this is feasible.
I'm back
D3s D700 D200, SB-900, SB-800 x2, SB-600 x4
ipv6ready
Postby DVEous on Sun Aug 07, 2005 5:34 pm
... Obsolete ...
DVEous
Postby Onyx on Sun Aug 07, 2005 6:13 pm
VK4CP, it's not the specific notebook, I believe it's the chipset (Sonoma/i915, aka laptops advertised with Pentium M/Centrino 730, 740, 750, 760 etc CPU, as opposed to 735, 745, 755 etc. CPU). Glen has an Asus and he reports the same crash conditions with NC too.
The older versions of Capture (pre-4.2) can be made to function beyond its 30 day trial period with commonly found serial numbers on the net (please do not read this as DSLRusers' encouragement, endorsement or support of software piracy - further discussion of this matter should be avoided on this public board). These can then be updated to the current versions for continued use. However since NC 4.2, the serial no. format was completely overhauled. Installing with a legitimate serial/key from the current versions of NC should eliminated all these issues.
If you can live with the compromises in build quality and India-based tech support, The Inspiron 6000 seems to offer a good value package.
Onyx
Capture Cras
Postby Digidegs on Sat Oct 08, 2005 12:14 am
Hi all
I have a new HP 6004 17inch laptop. P4 3.2
Also crashes when NC starts. Loads but when you click on it to start it crashes, not even a chance to put in the key.
Have treid many things even utility to sort out the registry entries and re install. Gave up.
It installed OK on my HP TC1100 Tablet PC also running XPP Tablet with serv pack 2. This one a P4 M processor. Works Fine but I need it on the laptop not the tablet.
I will try some of the solutions posted. Thanks
Cheers Albert
Digidegs
Return to Equipment Reviews
