Airborne Combat
Airborne Combat
Postby MHD on Tue Dec 27, 2005 11:33 am
This is a sequence of images (heavily) cropped that I took at Dee Why beach yesterday... I know they are quite technically imperfect, (blown and not the sharpest)... but I thought I might as well post them :) I like the poses...
How are you meant to be able to spot meter on a moving subject!?
New page
http://www.potofgrass.com
Portfolio...
http://images.potofgrass.com
MHD
Postby Alpha_7 on Tue Dec 27, 2005 11:42 am
Nice Scott, as you said technically they aren't great, but they tell the story and capture the moment well. So what was the final outcome, did the first make off with all the bread ?
Postby MHD on Tue Dec 27, 2005 11:59 am
As far as I could tell :)
New page
Portfolio...
MHD
Postby avkomp on Tue Dec 27, 2005 1:29 pm
I generally dont spot meter on flying birds that are likely to be flying erratically,
I usually use centre weighed though, I generally find flying birds to be relatively small in the frame and tend to get better exposed shots.
In side by side tests with the d70 I found a tendency to underexpose birds
especially when the sky was bright,
Aperture priority will usually be the best bet expecially if the bird is flying across varying lighting positions.
I try to use fill flash also.
exposure compensation may be necessary also, depending on the colour of the birds.
Early morning light is usually the sweetest for bird photography with late arvo being the next best.
Around midday the light will be harsh.
Seagulls are a good source of practice for bird flight shots because they are common and used to man and often come around to steal chips etc.
Also, because they are bright white you can get a feel for what exposure compensation is necessary.
Postby kipper on Tue Dec 27, 2005 3:53 pm
I usually position myself with the sun facing behind me and manually set the exposure and leave it as I've had too many instances of birds moving and the sensor not being position correctly so exposures differ between frames.
Darryl (aka Kipper)
Nikon D200
kipper
Postby avkomp on Tue Dec 27, 2005 4:35 pm
Darryl, I quite often do the same, but there are times where I want to get something that goes where I dont want it and then I have lost shots whilst I changed exposure.
those are the times I cop the difference in exposure.
steve
Postby Dug on Tue Dec 27, 2005 5:20 pm
Go to beach
Spot meter bird
Set exposure
Throw pilchards
Wait
:D :D :D :D :D :D :D :D :D :D
Dug
Postby Steffen on Tue Dec 27, 2005 8:07 pm
Wouldn't spot metering a white bird underexpose it (make it 18% gray)?
Steffen.
Steffen
