| Got a thin skin? Then look elsewhere. Post a link to an image that you've made, and invite others to offer their critiques. Honesty is encouraged, but please be positive in your constructive criticism. Flaming and just plain nastiness will not be tolerated. Please note that this is not an area for you to showcase your images, nor is this a place for you to show-off where you have been. This is an area for you to post images so that you may share with us a technique that you have mastered, or are trying to master. Typically, no more than about four images should be posted in any one post or thread, and the maximum size of any side of any image should not exceed 950 px.
			Forum rulesPlease note that image critiquing is a matter of give and take: if you post images for critique, and you then expect to receive criticism, then it is also reasonable, fair and appropriate that, in return, you post your critique of the images of other members here as a matter of courtesy. So please do offer your critique of the images of others; your opinion is important, and will help everyone here enjoy their visit to far greater extent.
			 by jonnydee on Sat Jan 08, 2005 10:26 am
 Hi all,
 Thought i'd share some pictures I took tfof the opera house sails yesterday.  I quite like the first one, not too sure of the others.  Think they might be a bit washed out though, the sky isn't as blue as i'd like.  I've got the raw files, could anyone give me any tips on beefing up the blue of the sky?
 Thanks!
 Jon
 <a href="http://jonnydee.smugmug.com/gallery/348576/1/13854103">Originals in gallery</a>
				 jonnydee
Member Posts: 95Joined: Mon Jan 03, 2005 1:45 pmLocation: Northern Beaches, Sydney
 by sirhc55 on Sat Jan 08, 2005 11:00 am
 jonnydee
 I pulled the middle photo out and opened in PS  - check out your levels - pull the left hand marker across to see an increase in contrast and definition. It’s a start.
 Nicely composed pics
 ChrisChris--------------------------------
Key Member Posts: 12930Joined: Fri Sep 17, 2004 6:57 pmLocation: Port Macquarie - Olympus EM-10
 by Manta on Sat Jan 08, 2005 11:13 am
 sirhc55 wrote:jonnydee I pulled the middle photo out and opened in PS  - check out your levels - pull the left hand marker across to see an increase in contrast and definition. It’s a start. Nicely composed pics Chris
 Liked the photos jonnydee but I agree that those harsh summer skies look a bit weak. I played with the last photo in PS  and got some good results by selecting just the sky with the Magic Wand tool then adjusting the levels (you'll see what improvements can be made when you look at the graph) and also playing with the saturation and lightness to get the desired colour. The benefit of this method is that it only affects the sky and leaves the remainder alone.
Former Outstanding Member Of The Year Posts: 3815Joined: Tue Nov 30, 2004 10:49 pmLocation: Hamilton Qld
 by jonnydee on Sat Jan 08, 2005 12:53 pm
 Thanks for the tips!  I've had another go with the origianls and come up with a more balanced result I think.
 Jon
				 jonnydee
 by Manta on Sat Jan 08, 2005 1:02 pm
 Much better result, Jon. Well done.
 by leek on Sat Jan 08, 2005 5:25 pm
 I love the adjusted photo...
 What white balance settings did you use, or did you do anything to adjust the colour of the sails in PP? The reason I ask is that last time I was down there the sails were looking a little yellow and jaded...
				 leek
Senior Member Posts: 3135Joined: Thu Dec 23, 2004 4:46 pmLocation: Lane Cove, Sydney
 by Onyx on Sat Jan 08, 2005 8:36 pm
 Jon, the sails almost look plastic with their shiny bright white appearance. As abstract art pieces, I think they would work.
				 Onyx
Senior Member Posts: 3631Joined: Sat Aug 07, 2004 6:51 pmLocation: westsyd.nsw.au
 by jonnydee on Sun Jan 09, 2005 10:30 am
 Leek, I used the direct sunlight WB setting, then I just tweaked the white end of the levels a bit in photoshop, didn't touch the colour.  I think the sun was just very strong directly onto the sails,  leading to that shiny kind of look.
				 jonnydee
 Return to Image Reviews and Critiques |
