Light Leak (non-digi)
Postby jerrysk8 on Tue Aug 08, 2006 11:47 am
thought i'd post this even tho its on film not digi. bumming about the light leak :x. luckily it only happened to this pic and its one i'm not diggin too much. now to find and fix the leak in my back grrr.
harry - roof ollie. valley.
jerrysk8
Postby marcotrov on Tue Aug 08, 2006 12:18 pm
Jerry S can't actually see your image for some reason, it may be blocked by the proxy but it depends where the light leak is as to which part of the back door you need to refer. Don't forget about the orientaion of your film in the camera and that when you view the print it will be relative to the film(upside down etc) being exposed in your camera. The other point is I had this issue once and found out that the film i was using had a thin aluminium stick on tag that was just enough to raise the back door so light crept in occasionally. Good luck cause I know it can be frustrating. :x
Postby PiroStitch on Tue Aug 08, 2006 12:23 pm
light leak or not, still a bloody awesome pic :)
Postby jerrysk8 on Thu Aug 10, 2006 2:37 pm
i dropped the back once hence the light leak. it only leaks when the light hits it at a certain angle so it only leaked on one pic. oh well. bronny backs are cheap as compared to hassy ones so i'll just buy another.
thanks pirostitch
jerrysk8
Postby Hyena on Fri Aug 11, 2006 10:32 am
Why not salvage the pic and go with a scifi theme - you could claim he was caught in some sort of tractor beam/stasis field :lol:
Hyena
