Edit: Replaced the first image with an improved version
Candids @ The HopModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Candids @ The HopSome candids from the AW ferry hop last weekend. More can be found HERE. As I am wont to say - not my usual style.
![]() ![]() ![]() ![]() Edit: Replaced the first image with an improved version Last edited by stubbsy on Wed Aug 09, 2006 9:05 pm, edited 2 times in total.
Peter - is there a PS effect on #1 of Jack? Just looked at the larger verison, looks a little out of the ordinary.
Geoff - Thanks for the tip on #1 - I overdid the sharpening & noise reduction. Replaced with a redone version.
Nick - the shot of Paul REALLY annoys me. I like the composition and everything about the shot except the DOF is shallow as you say so Paul's nose is in focus, but not his eyes. I came close to dumping the image, but ti's other qualities wone me over. Peter
Liam These were put through DxO Optics Pro using it's default settings. For these images they ended up with a slight yellow cast which I then removed in Photoshop using the Nik Color Efex Remove Color Cast filter. That's it. Apart from the shot of Paul, these were taken with the 28-70 f/2.8 which seems to render very crisp images. Peter
Peter, it is still an excellent shot. I'd be very happy to have taken it. The DOF is a small pity - if your image was not so strong it would be much more of a detractor. EDIT: Just noticed with your frames that the top is slightly shorter than the sides - I think it would look better if the top and sides were equal but the bottom larger like it is. - Nick
Gallery
