Pretty happy with this first one.
More here.
Old Train YardModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Old Train YardHere's a couple from the Australian Technology Park at Redfern, Sydney, formerly a train yard. C&C appreciated...
Pretty happy with this first one. ![]() ![]() ![]() ![]() More here. Cheers,
macka a.k.a. Kris
Macka - I can't view these through my work system (doesn't like SwimminginaFishBowl at all!) but I'll check them out later at home.
![]() Simon
2nd one is very nice, the contrast between the dark blue sky and the door
i would just distort the image a little so the top horizontal line is horizontal but as is it does have that whacky characteristic quirk
Thanks guys.
Simon - Sorry, not sure what the problem is. ![]() Wendell - How would I go about distorting it. I have so much trouble photographing buildings - I get so confused by the lines and the distortion. Oscar - thanks.
I'm not sure I know what you mean. Do you mean it needs straightening? Cheers,
macka a.k.a. Kris
hi macka if that's your real name in photoshop if you know how to use the guides pull a horizontal one down to the top horizontal of the building then select all and select menu 'edit' then 'transform' then 'free distort' you will see 4 handlers(boxes) on each corner move them about you'll get the gist of it, it's easy to move this around if you extend the window to full screen annd zoom the image out so you have soem buffer space around the image after you doen movin those handlers and distrorting yout image press enter done manipulating hte image digitally is cheaper than buying a rectalinear lens or whatever they are called
Not a problem at your end Kris - just our over-zealous filtering system. As for the images (now that I can see them!) - I really like them all. Strong and in-your-face! As far as critique is concerned: the windows (aluminium frames?) don't quite sit right in the second shot - they just look out of place. Suggest you find the builder and give him what-for! To my eye, you can get away with the perspective shift in the first shot but it's really apparent in the second, twisting the image a little - compare a verticle edge on the left of the corrugated iron to one on the right. I'm not sure fixing this would make for a better shot though... I love the tree and seats - beautifully composed! Simon
Dougie & Simon, Thanks.
Alright, here's my attepmt at correcting the distortion on image #1 using transform -> perspective. I must admit it didn't really bother me, but now that I've done this I see what you're all talking about. Still not perfect but, I don't think it ever will be without one of those fancy tiltshift lenses. ![]() Edit: If anyone else wants to have a go, feel free. Here's the yellow door corrected: ![]() Cheers,
macka a.k.a. Kris
