B&W for $15.40 (part II)
Postby firsty on Sat Sep 02, 2006 8:43 pm
here are some of the B&W photos from my Color photography expedition I tool on Wednesday
(see the "Color for $15.40" thread) http://www.dslrusers.com/viewtopic.php?p=245829#245829
I have made up a slide show of my pick of the shots I took both color and B&W (the play button appears after a little bit of buffering)
the normal size and sound quality can be found at http://www.mcgoffs.net/aug30/index.html
a smaller size with low quality sound can be found here http://www.mcgoffs.net/aug30/small.html
or you can browse through at you leisure in my gallery here http://photos.mcgoffs.net/v/30aug06/
firsty
Postby jethro on Sat Sep 02, 2006 9:07 pm
Keith image no 3 is mind blowing
Jethro
shoot it real.
look! and see. Shoot and feel
jethro
Postby MATT on Sun Sep 03, 2006 11:03 am
Keith, lots of good images there.
The green tiles looked like the image was spinning and some great graffiti..
Well done.
A question, what software did you use to create the slideshow??
MATT
MATT
Postby firsty on Sun Sep 03, 2006 11:40 am
MATT wrote:A question, what software did you use to create the slideshow??
Matt
Thanks for the kind comments
the program is called Soundslides http://www.soundslides.com/
it is very easy to use just point it to the folder of photos you want to use and to your audio file then it opens an edit window where you drag and drop your photos to the final order you want, you can also change the timing of each photo with a simple sliders on a time line to fit with the music (or voice track if making a tutorial/editorial slideshow)
it defaults to making the 2 sizes as std but you can set it to a single size of your own dimensions if you like
I first saw it in the Sydney Morning Herald Photo Blog http://blogs.smh.com.au/photographers/
this shows it intended use http://www.smh.com.au/multimedia/drover/index.html
firsty
Postby MATT on Sun Sep 03, 2006 11:45 am
Thanks for the info Keith
MATT
MATT
Postby Oscar on Sun Sep 03, 2006 12:53 pm
Great shots Keith. The slideshow was cool - and what a cute puppy shot at the end of the slideshow. Cheers, Mick
Oscar
