Thankyou in advance for sharing your thoughts.
Great ocean road trip.Moderators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Great ocean road trip.Just started to go through all the pics i took on our recent road trips from Adelaide- Great Ocean rd - Adelaide Trip and though i would post a couple from the first leg of our trip....... Adelaide - Halls Gap - Lorne
Thankyou in advance for sharing your thoughts. ![]() ![]() ![]()
with the last shot of the waterfall, because it is lacking a lot of colour, i would try making it black and white and adding more contrast or playing with shadows/highlights levels. just a thought.
thanks. Nathan
D700 | MB-D10 | Nikkor 14-24 | Nikkor 24-70 | Sigma 70-200 | 20 2.8 28 2.8 35 2 50 1.8 | Sigma 105 | SB-800 http://www.flickr.com/nathanjphoto/
i think the b&w did help, but the boosted colour version i think has a bit of a green cast to the whole image, but the colours are much better
![]() Nathan
Adam, it is a bit hard to go into everything that I do as I tend to fiddle and fart about until I get what I think is to taste.. Also I am not aware of your expertise with Photoshop CS2. For the colours I have used selective colour and adjusted them to taste, in this case the yellow,green,cyan and blue. On the bright sky I used the shadow/high light filter to drop the sky tone down making sure that this adjustment was on a seperate layer as I need to mask off all areas other than the sky. On a separate layer again I have used brightness and contrast to add light to the foreground and waterfall selectively masking off some of the effect to the left and right middle ground. What I was trying to do was add detail (with light) through the middle of the image and up the waterfall leaving the sides darker to form a tunnel for the eye to follow. Hope this helps a tad, but seeing it done is the real way to understand what I'm trying to explain. Life is
Stephen
i really like waterfalls
i read through the topic posts and well the final waterfall is a much more improved version of the original shot....... well done. Its not all lost if the original didn't turn out after all..... you've got yourself a nice photo that could be even framed.........
Sheesh I just caught up with this thread - that final version of the waterfall is fantastic, this is probably the best example I've seen of what some skills in photoshop can allow you to do with an image!
Adame - to round this out can you share what you did to get the final result? D3 | 18-200VR | 50:1.4 | 28:2.8 | 35-70 2.8 | 12-24 f4
Yep definetly.
OK I reproscessed the RAW file being much more caefull to keep as much highlight and shadow detail in the finall .tiff image as possible. I actually had to reduce the contrast in My Raw software then adjusted the exposure compensation to suit. Took the resulting tiff into CS2 where i adjusted the Color balance, and curves. Also i added a gradient fill layer to remove some of the glareyness from the upper part of the image. Hmm as far as i can remember thats about it, i should really have saved it as a Photoshop document so i could see all the steps that i took ![]() I just get lost in what i dooing in photoshop and find at the end of an image i have actually completed about 50 more steps than i can remember. ![]() Cheers Adam
