Comments and criticisms encouraged.
Lonely BoathouseModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Lonely Boathouse![]() Comments and criticisms encouraged.
what a great example of a picture leading you in, great shot only small critisism i have is that it may have worked a touch better with a lower view point so the path seems closer at the bottom of the pic......
Awesome ![]()
great pic!
such a simple background, combined with the path leads your eyes straight to the boathouse Nathan
D700 | MB-D10 | Nikkor 14-24 | Nikkor 24-70 | Sigma 70-200 | 20 2.8 28 2.8 35 2 50 1.8 | Sigma 105 | SB-800 http://www.flickr.com/nathanjphoto/
Ahh you mean like crouch down and take it again? I suppose that would make the path seem longer? I will have to go back and try that again. Might have to wait awhile for a perfect day.
Matty
You could even lie flat on your stomach. I often do it to get the shot. One little point is that the image also seems very blue. Maybe warm it up a little in PP. Peter
Nice photo, just a suggestion, try cropping the bottom off where the shallow water begins and see what you think. I tried it by scrolling on the screen and I like it.
__________
Phillip **Nikon D7000**
That's a great shot Matty. I concur with Stubbsy, lie on the path to get the shot from an even lower angle. Another suggestion: it looks like you've used a polariser which is great to give the sky a dark blue dramatic effect, but you've got so much blue in the shot already. Try it without the polariser to tame the bleu a bit.
Cheers John D3, D300, 14-24/2.8, 24-70/2.8, 85/1.4, 80-400VR, 18-200VR, 105/2.8 VR macro, Sigma 150/2.8 macro
simple lines make this a very pleasing and calm image to view...... great capture......... have you tried cropping as a pano for a different look
Cool capture MattyO.
I agree this shot would look cool shot from a lower perspective. Maybe it would look better cropped as a portrait view so as to cut out the distractions on the opposite bank. This may also increase the feeling of isolation. Well done. Cheers, Mick ![]() ![]() ![]()
