My lightning shot
My lightning shot
Postby casnell on Tue Nov 14, 2006 8:52 pm
Don't want to steal Stargazers thunder(groan) with his POTW which is much better than mine, but I thought this was interesting for the thickness of the lightning bolt. Taken in Rome, that's the Pantheon roof you can see. No tripod, just a braced monopod which is why it's on a bit of an angle.
casnell
Postby surenj on Tue Nov 14, 2006 9:35 pm
Looks like you were relatively close to the lightning...was it very loud?
You may like to adjust to curves to make it darker so the ambient light is minimal...
Postby casnell on Tue Nov 14, 2006 9:44 pm
Seriously loud ! That was uncropped from 18mm...
I'll have a play with curves, I'm not much chop at PP.
Thanks, Chris.
casnell
Postby ozimax on Tue Nov 14, 2006 10:12 pm
In PS, open image, go to IMAGE-ROTATE-ARBITRARY- then maybe adjust 4-5deg CW, re-crop and you'll have a great image!
Edit: 3.5 deg or 4 deg will most probably do.
Postby Marvin on Tue Nov 14, 2006 10:51 pm
Wow, that's one hell of a lightning bolt!
Nikon D7000
Marvin
Postby casnell on Tue Nov 14, 2006 10:54 pm
More like this? Had a play with rotating, OK, had a play with curves, hmmmm?
casnell
