Bugatti Veyron (nickel-plated hot wheels model)
Postby BT*ist on Tue Jan 30, 2007 8:13 am
Using a desk lamp and television as my light sources and a tripod for stability, I took a couple of shots of a little Bugatti Veyron hot wheels car I got for Christmas. (The model is black nickel-plated, hence quite reflective... oh, and it's mounted on a mirrored base for an added degree of difficulty!)
While I like the effect of the metallic sheen in real life, I'm not sure how best to capture it - any C&C would be very appreciated!
BT*ist
Postby Pa on Tue Jan 30, 2007 11:20 am
you might have to use a light tent or similar.
cheers pa
cheers pa
http://pa.smugmug.com
Pa
Postby Raskill on Tue Jan 30, 2007 12:18 pm
I agree, use a light tent. There should be instructions somewhere around to make your own.
Once you make it, I would be tempted to take the image in the sun, allowing for maximum light, rather than multiple light sources.
Will be interesting to see how you go, it'll be a bugger!
http://www.awbphotos.com.au
Raskill
Postby Killakoala on Tue Jan 30, 2007 9:44 pm
The correct White Balance will improve it dramatically.
