Fire away!
Fire away!
Postby stubbsy on Wed Apr 25, 2007 9:58 pm
The image below is one from my recent Byron outing that I'm just not sure about so it's here for the collective wisdom of the forum to help me decide if it stays or if I hit the delete button. Does it just look like I joined two shots together (I didn't) or is it an interesting image?
To take the shot I was basically in front of the weir and lined up with the water surface. Tell me what you think - I have thick skin so if it's shit say so :lol:
Postby Alex on Wed Apr 25, 2007 10:03 pm
It works for me, Peter. It looks like an artifical type of waterfall. The only thing I find a bit annoying is the shadow area just the whole bottom part of the image really, is a bit too dark, i.e. I find it hard to follow what's happening in the lower part of the image. May be a bit of shadow/highlight would open that part of the image up? Apart from that it's an excellent photo.
Postby Matt. K on Wed Apr 25, 2007 10:27 pm
Nearly brilliant. I think you need to go back when the light is in a position to open those shadows in the foreground. 10 out of 10 for seeing the image and almost creating a masterpiece.
Postby Frankenstein on Wed Apr 25, 2007 10:33 pm
At first I didn't like it (and yes, first impression is of 2 shots joined). But it's an image that keeps drawing my eyes back, and the more I look, the better I like it - I thinks it's because of the interesting contrast between the colourful and detailed top half and the monochrome, plainer bottom half.
Keep it!
Frank
My photo gallery: http://www.frankalvaro.net
>>>> Nikon D300...Nikon 18-200 VR...Sigma 10-20...Tamron 90mm macro <<<<
"I've got an idea--an idea so smart that my head would explode if I even began to know what I'm talking about. " Peter Griffin
Frankenstein
Postby stubbsy on Wed Apr 25, 2007 11:16 pm
Thanks guys. I was bracketing when I took the shot (thought I'd try a HDR since I knew there was a big dynamic range in the scene). I just went back and manually merged the top of the shot above with the bottom of the slightly longer exposed image from the bracket to create the image below. I think this works now.
Edit: Fixed foreground colour cast
Postby Matt. K on Wed Apr 25, 2007 11:25 pm
Pull the blue/cyan out of the foreground and you have a winner...big time!
Postby sirhc55 on Wed Apr 25, 2007 11:31 pm
The background in the second shot looks very natural as opposed to the foreground. IMO the foreground needs to be taken back at least a stop so that is does not appera to be two different shots stuck together.
Postby stubbsy on Wed Apr 25, 2007 11:51 pm
Matt - thanks - I've update the second image to fix the colour cast.
Chris - these two shots were 1 EV apart in the bracket. When I merged them I reduced the lower half (the brighter of the 2) a little more. I think part of the problem is what worried me in the first place and that's the strong line across the image where the water goes over the weir.
Postby Alex on Thu Apr 26, 2007 12:12 am
stubbsy wrote:Matt - thanks - I've update the second image to fix the colour cast.
Looks great now Peter.
Postby sirhc55 on Thu Apr 26, 2007 12:40 am
Peter - I would try and merge the 2nd photo top with the first photo bottom :wink:
Postby aloysius on Thu Apr 26, 2007 2:25 am
sirhc55 wrote:Peter - I would try and merge the 2nd photo top with the first photo bottom :wink:
agree with that. the bottom in the first is much nicer than the second...as is the top in vice verca if that makes sense.
aloysius
Postby stubbsy on Thu Apr 26, 2007 3:21 pm
Umm the second photo top IS the first photo top it was the bottom I changed. I just improved my processing a little since when I looked at it again #1 seemed a little dull and dark. So I think what you really want is me to just process #1 the way I ended up processing the combined #2 :wink:
Postby Glen on Thu Apr 26, 2007 3:31 pm
Peter very impressive, second is my preference with just a little bit darker. Well spotted
