Harbour Bridge - Flukey?
Postby dviv on Wed May 16, 2007 11:07 pm
Took this from a boat on a cruise - 1/10sec handheld!
I'm struggling a bit with the horizon - when I rotate to make the horizon level, the bridge pylon looks silly (leans to the left). This is my attempt at compromise.
C&C Welcome!
dviv
Postby chrisk on Wed May 16, 2007 11:55 pm
VERY impressive given the circumstances. 1/10s on a moving BOAT :shock:
could use some fill light to bring it out a little more imo.
chrisk
Postby Yi-P on Thu May 17, 2007 11:03 am
1/10 on a moving boat :shock: You must have VERY steady hands :)
Postby dviv on Thu May 17, 2007 11:42 am
Yi-P wrote:1/10 on a moving boat :shock: You must have VERY steady hands :)
Not normally :lol:
I think I just got lucky - the boat was probably moving in directly the opposite way my hands were at that instant :D
Any ideas about the horizon?
dviv
Postby Cre8tivepixels on Thu May 17, 2007 12:25 pm
Cool.....i like it very much!
Dan
Cre8tivepixels
Postby Yi-P on Thu May 17, 2007 12:34 pm
dviv wrote:Any ideas about the horizon?
Did you use an ultra-wide angle lens? If that is the case, try to correct the barrel distortion first then level your horizons... :)
Postby Reschsmooth on Thu May 17, 2007 12:35 pm
dviv wrote:I think I just got lucky - the boat was probably moving in directly the opposite way my hands were at that instant :D
That's a very crude and inconvenient, yet effective image stabilisation technique! :lol: Cheaper than a VR/IS lens?
Our mug is smug
Postby gstark on Thu May 17, 2007 12:44 pm
Dunno. Boats can get quite expensive.
Especially in terms of maintenance.
Postby dviv on Thu May 17, 2007 12:50 pm
Yi-P wrote:Did you use an ultra-wide angle lens? If that is the case, try to correct the barrel distortion first then level your horizons... :)
Thanks Yi-P
I took the photo with the Canon kit lens (18-55) at 18mm (on 350D so 1.6x).
How would I remove barrel distortion? (bit of a noob at PP :oops: )
dviv
Postby dviv on Thu May 17, 2007 12:54 pm
gstark wrote:Dunno. Boats can get quite expensive.
 LOL not to mention it's fairly unreliable - took 6 or seven shots to get one (vaguely) sharp one!
dviv
Postby seeto.centric on Thu May 17, 2007 11:17 pm
spray and pray :wink:
ill admit most of my fave pix are flukies..
-j
seeto.centric
Postby Yi-P on Fri May 18, 2007 12:55 am
Thanks Yi-P
It is very hard to tell if it is a barrel distortion to start off with because the image is quite dark there...
But to remove that, if you have PS CS2, just go into filters->distortion->lens correction
and then play around with stuffs inside until you get a good feel of things gone back straight. :D
Postby dviv on Fri May 18, 2007 2:03 pm
Yi-P wrote:It is very hard to tell if it is a barrel distortion to start off with because the image is quite dark there...
Thanks Yi-P - Much appreciated!
I'll give it a go tonight and see what happens :lol:
dviv
Postby Reschsmooth on Fri May 18, 2007 2:43 pm
You are talking about boats and not women, right? :lol: :lol: :lol: (standard "do not tell Alicia I said that" requests apply).
P
Our mug is smug
