Another new and old comparison
Postby Alpha_7 on Thu May 24, 2007 12:49 pm
Through a lot of trial and error and playing around I think I'm starting to get some semi decent results with my temporary dual flash setup. Again I wanted to demonstrate his current head shot (another Aircondition closet era shot) vs two of the few he's considering.
The setup in for the rear flash didn't change between the two new shots, both had the SB-800 at 1/4 power close behind the subject, with the LS PJ+ Dome to provide a slightly diffused rim light.
The front flash was through a white brollie and at 1/8 or 1/4 power I tweaked as I went depending on the exact position again it was a metre to 2 metres from the subject and moved around on a arc with the centre being the subject. (if that makes sense.
Please give me plenty of feedback as I want to get as much out of having the extra kit and semi willing subjects as I can, the more I learn now the better as I'll be back to a single Sb-800 soon. What else am I missing that could make this better ?
#1 EXIF unavailable (sorry) D70
#2 D200, 1/250s, ISO 160, f5
#3 D200, 1/250s, ISO 160, f5
Postby Reschsmooth on Thu May 24, 2007 12:54 pm
Craig, you have come a long way in the few days you have had the lights. The third is best as the balance between rim and main light is much better, and you have avoided the glowing ear distraction. :lol: Well done.
I wouldn't mind seeing a bit more contrast in the main lighting, although I am not sure if this would add too many unwanted shadows.
P
Our mug is smug
Postby DaveB on Thu May 24, 2007 12:57 pm
#3 is much better than #2, but mainly just because his ear isn't glowing! BTW, #1 looks like a black background has been digitally inserted...
DaveB
Postby Alpha_7 on Thu May 24, 2007 12:59 pm
Thanks Patrick, I must confess the original #3 suffered very badly from glowing alien ear syndrome but after much mucking around I've made it look semi human now.. still not happy but I was pushing my PP skills to save it. Sadly the ears where something I was checking on the cameras LCD (lesson learnt).
Postby Alpha_7 on Fri May 25, 2007 10:40 am
I thought I'd add one more the the mix (since I can post 4).
Again please give me feedback as I want to make the most out of having the lights at my disposal.
#4 D200, ISO 160, 1/250", F5
Postby gstark on Fri May 25, 2007 10:48 am
Craig,
Look at #3 .... look at how the rim lighting is extending down his shoulder, providing a greater level of separation between the subject and background. This (IMHO) is probably what you should be looking to acheive.
Along with the greater subtlety of the effect in #4.
Try for a little less power (or greater flash-to-subject distance) on the rear flash, and aim more towards both shoulders and his back. If you can gain a greater spread with diffusion, so much the better.
is the rear flash positioned directly behind the subject, or off to one side?
Postby Alpha_7 on Fri May 25, 2007 4:13 pm
Thanks Gary your feedback was very helpful, and I see what you mean its all a balancing and next time I get someone posing for me I'll keep your advice in mind.
Postby stetner on Sun May 27, 2007 1:25 pm
In #3 did you photoshop the glowing ear? I see a dark area extending below and around the ear that looks like the masking is too large for the ear.....
stetner
Postby Pehpsi on Sun May 27, 2007 2:28 pm
I know nothing about portraits but 2 & 3 are excellent, lighting and clarity look very good :)
Nikon D70
12-24 DX, 18-70 DX, 70-200 VR
20" iMac Intel C2D
Aperture 2.1
PS CS3
Pehpsi
Postby Alpha_7 on Sun May 27, 2007 5:16 pm
stetner wrote:In #3 did you photoshop the glowing ear? I see a dark area extending below and around the ear that looks like the masking is too large for the ear.....
Yes sloppy PP work on my side of things, I noticed when I posted but haven't fixed it yet.
