by adam on Fri Jun 01, 2007 8:15 pm
I tried taking photographs of myself today (since I got a haircut)
I wanted to open the aperture to make it shallower depth of field, but the main problem is with focussing - what's the best way to focus on myself when I'm running backwards and forwards to press the shutter button then running back to pose.
I tried a number of different "poses", what are the techniques/tips of posing?
My friend said that I should be more natural.
Equipment: camera body, wide lens, standard lens, telephoto lens, flash
Wish list: skill
adam
by Reschsmooth on Fri Jun 01, 2007 8:40 pm
Adam, to focus, I would suggest mark the floor where you are going to stand, and try to manually focus to that position.
In terms of pose, others have a better idea than me
P
Our mug is smug
by Yi-P on Fri Jun 01, 2007 8:42 pm
You should get yourself a remote control so that you dont have to run back and forth...
For focusing, use a tripod, pole or something tall, focus on that, change into manual focus so it stays there, and just remove the tripod/pole when you take the photo. Unless you want the pole to be with you in the shots
Regarding posing, it is all about what type of photograph you want to achieve, general advise is to keep strong eye contacts, and natural shape of the body, or if you want to experiment with those artistic looks, bend what it can be bent... cross them if you can... its very broad meaning, but just experiment and get some inspirations around the net, there should be plenty to fill your taste.
by adam on Fri Jun 01, 2007 8:53 pm
Thanks Reschsmooth and Yi-P
Those tips were very helpful Yi-P, things I will certainly think about and keep in mind! I shall meditate on those! putting the pole there is also a good idea!
I shall try more after exams!
Wish list: skill
adam
by methd on Sat Jun 02, 2007 12:27 am
I used to live in Morley... long way away now
methd
- Member
by Old Bob on Sat Jun 02, 2007 12:29 am
You could try doing some "pole dancing". That would get some attention.
Bob
Old Bob
- Member
by adam on Sat Jun 02, 2007 1:03 am
Haha cool methd  Perhaps we lived very nearby!
If I had a pole there to dance around, it would solve the focus guessing also  I'll try it, for you. After exams!!!!!!!!
Wish list: skill
adam
