WedgieModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
WedgieNo not that one, a wedge tail eagle
![]() ![]() "The good thing about meditation is that it makes doing nothing respectable"
Re: WedgieNice capture
![]() I have always had difficulty with shadows which accounts for most of the bird against a bright sky. Please tell... Did you have to do much processing to get the shadow detail? If so, what did you do? Any tricks to the exposure? Regards Andrew
Re: WedgieAndy you are right about the shadows and I had to bring out a little detail in PS otherwise the underside of the eagle would have been too dark. I shot in aperture priority and trusted that the the shutter speed would be enough to freeze the birds flight, which luckily it was.
Re: WedgieSuperb John. Terrific detail and sharpness. Was thgis with your trusty 80-400mm? (Or have you since sold that off?) How close was the eagle - close enough for a Better Beamer/Flash Extender to light up the underwing areas? 60m or so would probably be the maximum.
Re: WedgieHi Simon yup the 80-400 at it's limit (just a slight crop), don't think the BB would have been much use at that range and in any case I didn't really have the time. Those birds are sure aware of humans.
Re: WedgieYep - fair point about the BB set-up time John. I find it's either on or off; not something you can quickly scramble for when a fleeting opportunity presents itself. Still, you proven here that you didn't need it anyway!
Re: Wedgiemust of flew pasted while having coffee then
![]() Cheers ....bp....
Re: WedgieGreat shot John,
they don't really hang around when they see two legged animals around ![]() Very nice framing as well. cheers, André Photography, as a powerful medium of expression and communications, offers an infinite variety of perception, interpretation and execution. Ansel Adams
(misc Nikon stuff)
Re: WedgieHi John. Lovely shot to add to previous comments. A question ... Is the 80-400 working better with the D3?
In the end we know Nothing, but in the meantime Learn like crazy.
Your Camera Does Matter Nikon D70 D200 D300 PPOK
Re: WedgieIt worked fine with the D2X - define better.
Re: WedgieThe key thing with bird images I have experienced is lock on and ISO. I always seem to get a potentially good image in failing light so I imagine that the D3 with its higher ISO potential (and noise control) would help in obtaining useable images with the 80-400 much more often. Also, I noticed a big improvement from the D70 to D200 with the 80-400, so I am supposing that there would be a noticeable increase in obtaining a focus lock with the D3 from the D2x. Continuous focus would be important for flight images. Better might be quantifiable in these two cases.
![]() In the end we know Nothing, but in the meantime Learn like crazy.
Re: WedgieLovely image John. The 80-400 (and your talent) shines again. Well i should imagine your chest and arms wouold have expanded quite a bit after lugging around the big D3 80-400 combo
![]() ![]() cheers marco
Re: WedgieThanks Marco, it is quite a heavy combo, but I am built close to the ground and fairly stocky. I certainly cannot hold it up to my eye for extended periods, but then again, for the sort of work I do it is not necessary.
Re: WedgieAwsome bird
![]() Great shot mate ![]() Cheers cobby
