ImpactModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
ImpactA droplet of milk at the moment of impact. The swirl was a by product of a few attempts and me stirring the milk into the red base. C&C most welcome. Click for larger
![]() Last edited by Nigell on Sat Apr 12, 2008 9:21 pm, edited 2 times in total.
Re: ImpactNice shot!
Gos 'spin' on the other droplet shots. Saw the original, were you using a high ISO? D80, D90 | SB600 | 18-200 VR | 80 400 VR | 18-135 DX AF-S, 70-300 AF, 50 1.8 | Lotz of other bitz
Re: ImpactNo, but my camera will only sync to 1/250 with the flash, so I was limited to what I wanted to do. I would have liked to have used 1/1000th. Still the moment is there, and to get the shot like it is was pretty lucky. So I will take it.
Re: Impactnice ...very nice
Re: ImpactPerhaps I should have put this image in a separate thread. As with the other image. A droplet of milk in a bowl. C&C most welcome.
Re: ImpactNice shot, welcome captured.
Re: ImpactI fixed the first shot which looked a little flat (I forgot to change it from Adobe RGB to SRGB). Should be better now.
Re: Impact
As long as you eliminate ambient light from influencing the exposure, by using a smallish aperture and a fairly low light level, the shutter speed is irrelevant in this sort of shot - the exposure duration is governed solely by the flash duration - hence the effect you see. To get a better "hit rate" you could look into making a simple sound trigger - I think Jaycar might have a kit. Cheers What's another word for "thesaurus"?
Re: ImpactI figured it all out by the end. The bowl shot was a 10 second exposure.
