ANDRA Winternationals - foolin' around
Postby Dipstix Pix on Wed Jun 11, 2008 3:10 pm
Went to the ANDRA Winternationals near Brisbane last weekend. Thought I’d have a go at some side flash. In the old film daze I use to have up to three flashes hooked up to my Pentax 6 x 7 (one on each side of the camera and one down track).
Now with digital age I thought I’d give my two Canon 580s a whirl – setting up the slave unit down track. My biggest problem was the fact other photogs would lean over the wall cutting off the line of site to the slave so I lost a heap of shots. Started off with the 300mm 2.8 on wide open at 1600 ASA. This one of Amanda Shepherd’s fuel car worked out OK
This pic of Aaron Deery in a alky car wasn’t as explosive without flames but I still thought I did reasonably well.
After a couple of hours of having the slave’s beam interrupted I moved closer to the startline with a shorter lens. This one is what I was hoping for but is a bit constrasty.
I love the color of this car and even though the wheels aren’t off the ground this looks pretty mean me thinks
This was one of the shots that the flash was interrupted but I don’t think it needs it. These are awesome cars to be but mere feet from.
http://img.photobucket.com/albums/v318/ ... ynch-1.jpg
Canon 40D | 30D | 10-22mm EF-S f 3.5-4.5 USM | 15mm EF f2.8 | 17-40mmEF f4L USM | 24-70mm f2.8L USM| 85mm f1.8 USM | 70-200 f 2.8L USM| 100-400 f 5.6 L IS USM| 300mm f2.8L IS USM | 2 x 580 EXII | 1.4 conv | 2x conv |
Dipstix Pix
Re: ANDRA Winternationals - foolin' around
Postby bwhinnen on Wed Jun 11, 2008 3:27 pm
I was wondering who was using the 580 perched on the wall!
Worked really well!
I just wish I could go up that high in the ISO though!
Great work Jon!
bwhinnen
Postby kiwi on Wed Jun 11, 2008 4:20 pm
Really like this series, thanks for posting your thought process too. I think the flash worked well.
I know I'd be constantly worried and checking out the 580's to make sure they didn't walk off...!!
Darren
Nikon D3 and Nikon Glass
kiwi
Postby bwhinnen on Wed Jun 11, 2008 4:38 pm
kiwifamily wrote:Really like this series, thanks for posting your thought process too. I think the flash worked well.
Na all the photogs at the event are really good. We all keep an eye out on each others gear. And the drivers, crew and officials are the only other ones to have access to the area so it is pretty safe. No general public allowed.
bwhinnen
Postby Pehpsi on Wed Jun 11, 2008 5:05 pm
Works really well, top results mate. First pic is wicked, and I can see my dad :)
Looks like the driver is staring directly at your flash on the wall in the 2nd pic :) The 3rd shows the full extent of the flash from the side.
Nikon D70
12-24 DX, 18-70 DX, 70-200 VR
20" iMac Intel C2D
Aperture 2.1
PS CS3
Pehpsi
Postby Dipstix Pix on Wed Jun 11, 2008 5:38 pm
Thanks for that - with up to thirty photogs there you have to try and do something different. :violin:
Dipstix Pix
Postby bwhinnen on Wed Jun 11, 2008 5:48 pm
Dipstix Pix wrote:Thanks for that - with up to thirty photogs there you have to try and do something different. :violin:
Is WSID worse for the number of photogs? I was actually expecting more at the Winternats than we actually got.
bwhinnen
Postby Flatpick on Wed Jun 11, 2008 5:55 pm
Good pic's there old fella :up:
Flatpick
Postby Flatpick on Wed Jun 11, 2008 6:05 pm
Some meetings at WSID can get busy Brett, I was pleasantly surprised with the number of photog's at the Winters, what helped was letting us go down as far as the 330 ft marker, really opened up the options as far as lens choice, before it was all 70-200 and every one wanted that sweet spot, a good move by Willowbank.
Flatpick
