My Model
My Model
Postby Catcha on Sun Jun 29, 2008 7:50 am
After a night out with my wife.She wanted some pictures taken for facebook.
Decided to take SB800 give it a bit of a run
1/60 sec at f5.6 ISO 800 40mm SB800 set at TTL pointed directly straight up into the ceiling
1/60 sec at f 5.6 ISO 800 45mm SB800 set at TTL flash pointed to the right with the white diffuser
Ben Yu
D300,SB800,Sigma 10-20,Mini Trekker Classic,Nova 3,Ixus 55 Other toys coming very soon..stayed tuned !!!!
Check out my site http://byu88.smugmug.com<>http://photobucket.com/byu88
Catcha
Location: Darwin, Northern Territory Was the only true open speed limts in Australia
Re: My Model
Postby phillipb on Sun Jun 29, 2008 11:07 am
Ben, I think the second one is much better, but you need to pay a bit more attention to the background. The white strip directly behind doesn't help. It would be better if you moved away from the wall a bit more and reduced DoF.
__________
Phillip
**Nikon D7000**
phillipb
Re: My Model
Postby shakey on Sun Jun 29, 2008 11:12 am
The white strip in the background and the bit of furniture or whatever on the lower left hand side of the frame are a bit of a distraction.
But much better than the shots I take after a night out. :)
Edit...Phillip got there before me...nothing like simultaneous posts... :)
shakey
Re: My Model
Postby Catcha on Sun Jun 29, 2008 2:39 pm
Thanks for the comments, hmm yeah it was in the room, should of moved her to the left or right a bit more to use the door as a backgroud or the wardrobe :mrgreen:
Ben Yu
Catcha
Re: My Model
Postby Catcha on Sun Jun 29, 2008 2:44 pm
phillipb wrote: It would be better if you moved away from the wall a bit more and reduced DoF.
Do you mean if I had moved her forward more to get more DOF it would of given a better effect ? But I guess if I reduced it DOF it was be the same as the photo. I think i'm confusing myself :roll:
Ben Yu
Catcha
Re: My Model
Postby phillipb on Sun Jun 29, 2008 5:55 pm
What I mean is move the model away from the wall and use an aperture of around f2.8 that way the background would be a bit more blurred.
__________
Phillip
**Nikon D7000**
phillipb
Re: My Model
Postby Catcha on Sun Jun 29, 2008 6:18 pm
phillipb wrote:What I mean is move the model away from the wall and use an aperture of around f2.8 that way the background would be a bit more blurred.
arrghhh icic thanks :D
Ben Yu
Catcha
Re: My Model
Postby aim54x on Sun Jun 29, 2008 9:10 pm
:agree: with moving the model away from the background more and the placement of that white strip. Also you may want to have a look at the WB of the shot, it may just be my monitor but she seems a little whited out with maybe just a little bit of a blue tinge.
Otherwise, top shots.
Re: My Model
Postby Catcha on Sun Jun 29, 2008 10:51 pm
aim54x wrote::agree: with moving the model away from the background more and the placement of that white strip. Also you may want to have a look at the WB of the shot, it may just be my monitor but she seems a little whited out with maybe just a little bit of a blue tinge.
Hmm whited out I think it might be all that make up and power :mrgreen: Thanks
Ben Yu
Catcha
Re: My Model
Postby surenj on Sun Jun 29, 2008 11:02 pm
:agree: with the others re: background.
You may want to balance flash and ambient a bit better ie increase your f stop and flash power so background is slightly darker and the light is slightly directional and soft(due to the wall on the left)
