The effect of aperture
Postby ATJ on Mon Nov 24, 2008 10:57 am
Here are 4 shots of the same dragonfly (Australian emerald, Hemicordulia australiae) but with different f/stops. The smaller the f/stop, the larger the aperture (hole through which the light passes), the more out of focus the background becomes. This is because depth of field (the distance of the scene in front of and behind the point of focus which appears to be sharp) is related to the f/stop. Smaller f/stops mean larger apertures and smaller depth of field.
f/16
f/8
f/5.6
f/4
Re: The effect of aperture
Postby dviv on Mon Nov 24, 2008 11:07 am
Nice tutorial Andrew :up:
And a nice shot of the dragonfly as well
dviv
Postby aim54x on Mon Nov 24, 2008 12:28 pm
:agree: great stuff!!
Postby Antsl on Mon Nov 24, 2008 2:14 pm
ATJ wrote: The smaller the f/stop, the more out of focus the background becomes.
:shock:
can we clarify that for some of our more impressionable readers.....
The smaller the "f-stop number" the more out of focus the background becomes.
A small f-Stop number like f2.8 actually makes for a large aperture opening and this creates the small depth of field (hence out of focus backgrounds)
A large f-stop number like f22 means the aperture is closed down to a small size and this creates in large depth of field so that more of the image appears in focus.
Antsl
Postby gstark on Mon Nov 24, 2008 2:20 pm
Antsl wrote:A small f-Stop number like f2.8 actually makes for a large aperture opening
Which means there's a big hole through which the light may pass. :)
Which means there's a small hole through which the light may pass. :)
Postby ATJ on Mon Nov 24, 2008 2:26 pm
I have added further detail in the description.
Postby trublubiker on Mon Nov 24, 2008 3:58 pm
Good series of shots. Shows how DOF decreases as the size of the aperture increases.
The trick I'm trying to learn is to balance DOF with Bokeh when in Macro mode.
It sounds a bit like Lawn Bowls.
On a 'Fast' green your bowl takes around 17 seconds to cover 27m.
On a 'Slow' green your bowl takes around 10 seconds to cover 27m.
Go figure.
trublubiker
Postby Glen on Mon Nov 24, 2008 7:14 pm
Andrew great reference :up:
Thank You
Postby surenj on Tue Nov 25, 2008 11:35 pm
Great tute Andrew... May should be moved to the tutorial section?
