Its raining again (170mm in 24 hours) and I am off work today so had a play in the studio.
Mmmm...Moderators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Mmmm.......marshmallows, yummy.
Its raining again (170mm in 24 hours) and I am off work today so had a play in the studio. ![]() ![]() ![]() Fuji X-Pro1 | X-E1 | X-T1 | XF14 | XF23 | XF27 | XF35 | XF56 | XF60 | XF10-24 | XF18-55 | XF55-200 | MCEX-11
http://gmarshall.zenfolio.com http://xtographer.weebly.com
Re: Mmmm...Geoff, I have been producing pack shots for quite a few years and I would be more than happy to have these shots in my portfolio
![]() Chris
Re: Mmmm...Yummy indeed!
I wonder whether y ou can explain the lighting to the noobs (like me). I can't seem to reverse engineer this one easily. So far my guess is light below plexiglass, background red light and relatively soft kught from right of camera?
Re: Mmmm...
Of course I can, you are pretty much correct in your reverse engineering though - Off camera SB800 triggered from the on board pop up flash dialled down to -3, under an etched glass table top. The pop up flash provides a little front fill. Lighting from the right is natural daylight through a glass door. No lights on b/g - the first two are different coloured matt board, dark green & red, the third is from a higher viewpoint and what you can see is just the glass table top. Fuji X-Pro1 | X-E1 | X-T1 | XF14 | XF23 | XF27 | XF35 | XF56 | XF60 | XF10-24 | XF18-55 | XF55-200 | MCEX-11
