One versus self
One versus self
Postby surenj on Wed Dec 16, 2009 1:04 am
The remnants of the eternal struggle. :mrgreen:
For your critique as always. Thanks for your opinions.
Re: One versus self
Postby craig.rohse on Wed Dec 16, 2009 7:14 am
I like it Suren
It's like a character from the latest Zombie movie.
"Old school" (Olympus OM 1&2SP )
craig.rohse
Re: One versus self
Postby gstark on Wed Dec 16, 2009 7:47 am
Suren,
While a little of the photochopping you've done is obvious, I like this too. You are doing some great work of late, and your mind is working in overtime.
My only real niggle is that the reds on the lh side of the image (the edges of the hat, cheek and neck) are very typical of how easy it is to blow red highlights in digital photography. Reducing the intensity of the light source providing this light will help pull this back and give you more detail in this area.
Re: One versus self
Postby biggerry on Wed Dec 16, 2009 9:08 am
Suren, you been watching way too many spooky movies :shock:
Very creative on this one, as Gary mentioned the photochop is fairly obvious, however I reckon it would only take a small amount of tweaking to achieve that movie poster level!
I think there need to be a bit more clearance around the right eye (as the viewer looks at it) the white plastic layer needs to end around the eyebrow line.
Now I want to see the terminator version.... :up: :up:
Re: One versus self
Postby Big V on Wed Dec 16, 2009 11:57 am
Definately the terminator type look going on here - you will scare little children!!!
Canon
Big V
Re: One versus self
Postby devilla101 on Wed Dec 16, 2009 7:51 pm
:lol: lovin' it
Very interesting concept and well executed.
devilla101
Re: One versus self
Postby biggerry on Wed Dec 16, 2009 10:03 pm
lovin' it
methinks this image would go well photochopped with devilla101's cockatoo island shot. Saw meets terminator... :up:
Re: One versus self
Postby aim54x on Wed Dec 16, 2009 10:05 pm
Great stuff, very interesting concept...would love to see more.
Re: One versus self
Postby surenj on Fri Dec 18, 2009 2:16 am
craig.rohse wrote:I like it Suren
gstark wrote:I like this too
biggerry wrote:way too many spooky movies :shock:
Big V wrote:you will scare little children!!!
aim54x wrote:very interesting concept
Thanks everyone. Your comments are much appreciated.
gstark wrote:photochopping you've done is obvious
biggerry wrote:photochop is fairly obvious
Where is the most obvious bit? I want to improve on it.
biggerry wrote:white plastic layer needs to end around the eyebrow line.
Will make some adjustments. I was using the actual mask so didn't have much room to move. The mask doesn't fit the face in real life. [he wears this for dancing!]
biggerry wrote:terminator version...
Done... Check out the terminator post. Thanks for the idea!! :cheers:
Some background. I had this shot in mind (less the cracks) before we started shooting. We shot the mask seperately in the same light and combined exposures. The crack was another photo blended with some texture.
gstark wrote:how easy it is to blow red highlights in digital photography
Thanks for the tip Gary. I never knew of this phenomenon!! Although the LCD didn't show blown highlights(nor does LR), I can't revcover detail from it!!! I will need to watch out for the future. As per usual, I overexpose and pull back in post to minimise noise from my ancient camera.
Re: One versus self
Postby biggerry on Fri Dec 18, 2009 7:30 am
well i thought the mask was a photochop :shock: man was i wrong...
Both scars need some blending in, also darkening them a bit (neck one) would also help and hide any incorrect detail :up:
Re: One versus self
Postby gstark on Fri Dec 18, 2009 8:40 am
For me, it's where the white plastic meets the skin. Around the lh side as wee look at the face, and within the gap for the eye.
It appears to me that it's a photochop, rather than a real image, but I can't offer any ideas on how to improve it.
With red lighting, overexposing is not a good idea, because you will lose detail very quickly, That's why I don't like it when I get red stage lighting when I'm shooting theatre or band gigs or music festivals. You need to chimp carefully and try to pull the lighting back if you have control, or else push up some other light source, such as your on camera flash, to compensate.
It's a difficult task.
