by natskis on Sun Feb 21, 2010 12:01 am
Hi All, I've been mucking around with Polar Planets recently thanks to dstrom! The novelty hasn't worn off yet for me so I'm looking to make more. After someone mentioned that they look like you can pick them up in your hands, I thought that I could make an image that had me holding a couple of Polar Planets I had recently made. Here's the final result: The link can be found here: http://www.flickr.com/photos/27223142@N04/4372522934/ The Polar Planet on the left which is a stitched image of the Main Quadrangle in Sydney University can be found here: http://flic.kr/p/7Eose1The polar planet from the right is an image of Botany Bay made into a Polar Planet which can be found here: http://flic.kr/p/7CW9AbYes that's my ugly mug holding them  So I created a self portrait against a neutral background. I then put it all together in CS3. This was a very steep learning curve in CS3 from fudging shadows and light from the planets and trying to figure out how to make the planets go behind certain parts of my hands. I would LOVE to have some feedback on anything. From the planets, to the self portrait and especially my CS techniques
natskis
- Member
by surenj on Sun Feb 21, 2010 1:13 am
I am not so clear about these planets. Did you make them [plastic] or photoshop them completely?
by natskis on Sun Feb 21, 2010 9:30 am
surenj wrote:I am not so clear about these planets. Did you make them [plastic] or photoshop them completely?
Alll photoshop  I'm kinda chuffed that you thought they might have been plastic! Ok so the right hand Polar Planet was made using 16 stitched shots of botany bay. http://flic.kr/p/7EsE86I saw the tanker and thought that it would make a great polar planet. After doing some heavy Photoshopping and applying the Polar Planet filter, the final shot was this: http://flic.kr/p/7CW9AbThe left Planet I used this image: http://flic.kr/p/7AR2kuto make the Planet http://flic.kr/p/7Eose1Then I took a self portrait and photoshopped it all together. All up about 20 pictures. Lots of editing in Photoshop  If you want to know more about the polar planets. Here's a tutorial: http://content.photojojo.com/tutorials/ ... a-planets/They're very interesting that's for sure  I've never had to think about how light is cast from objects in pictures before and when I added the planets to my self portrait, I had to try and figure out how shadows/light would be cast.
natskis
- Member
by DStrom on Sun Feb 21, 2010 11:22 am
 ... nice But I think it would be better with a little off camera flash on you, and if you gave both of the planets a little more of a #D look. Some shadows etc.
DStrom
- Member
by zafra52 on Sun Feb 21, 2010 1:57 pm
I think special effects photography is more difficult than appears. The trick, I think, is to make it look natural - as if taken with a single shot. You've done very well, in fact better than I could do myself with my limited knowlede and Photoshop skills, but the spheres in your hands need a 3d effect, as mentioned above. Work on it. I am sure you can improve it further. A possible solution could be taking your own picture again holding two real glass balls and using them as frames to insert your worlds. Think of the crystal balls used by fortune tellers in the old movies with smoke inside and an image forming in them...
by DebT on Mon Feb 22, 2010 2:27 pm
Think this a great way of showing off your work , and thanks for sharing the link so I too can give them a go DebT
DebT "so many dreams - so little time "
DebT
