More Netball Action - Swifts v Steel
Postby dviv on Wed Jun 23, 2010 1:22 pm
Played around a bit more with focus modes at this game with very mixed results.
Also dropped the ISO down to 800 and did a bit of exposure comp in DPP to see if I get a better result (noise wise)
C & C would be appreciated - Semi's next week at Acer arena :up:
For those interested, The swifts went through the regular season undefeated.
dviv
Re: More Netball Action - Swifts v Steel
Postby Matt. K on Wed Jun 23, 2010 1:41 pm
These are outstanding netball images. The figures are larger than life and your low point of view adds to the already impressive impact in the pictures. Netball, like volleyball and basketball are notoriously difficult to photograph and it's almost a specialised field of photography for that reason. bloody good work!
Postby Big V on Wed Jun 23, 2010 3:56 pm
You have it nailed now - well done
Canon
Big V
Postby surenj on Wed Jun 23, 2010 7:40 pm
:agree: with Matt and BigV.
I am however concerned about the noise in these? I assume that's the JPG conversion?
If not, then you need to use ISO1600 and 'correctly' expose rather than underexpose at ISO800. I assume you are using the 7D which has a ceiling ISO of 12800.
Which focus mode and lens are you using?
Postby zafra52 on Wed Jun 23, 2010 7:53 pm
Fantastic action shots! As above, I am curious about
the camera and lens you used. I am considering my
next camera upgrade and half of me wants the 5D II;
while the other thinks the 7D would be more realistic
because of the lenses I already got.
Postby biggerry on Wed Jun 23, 2010 9:53 pm
surenj wrote:Which focus mode and lens are you using?
me too, I am interested in your focusing technique, do you have consistent focus during these games?
The first comes across a bit OOF, however the second and third are real crackers, the timing and composition is nailed, even if there is noise in the image this is offset by the frame timing!
you must really be enjoying this netball and getting to know it well now! :up: :up:
Postby -=Monty=- on Wed Jun 23, 2010 10:29 pm
Very, very well captured; love them.
Have you tried playing around a bit with the white balance? I understand that the floor is reflecting some orange-coloured light up, but skin tones seem just a little TOO unnatural in my opinion.
D300|D70|24-70mm|70-200mm VR II|10.5mm Fisheye|70-300VR|50mm F1.8|Rokinon 85mm f1.4|SB-900/800/600
flickr
-=Monty=-
Postby dviv on Thu Jun 24, 2010 10:13 am
Thanks for the kind comments everyone - Much appreciated. :cheers:
-=Monty=- wrote:Have you tried playing around a bit with the white balance?
Nope :D But you're right, they may be a bit warm.
zafra52 wrote:I am curious about the camera and lens you used.
These were all with the 7D and the 50 F/1.4 shooting at 1.8. I had the same decision to make but chose the 7D for a few reasons: Master Flash, Better focus mode, EF-s lenses and Price.
I'd love to have a 7D and a 5DII so I could use the 7D for sport and the 5D for outright image quality... but don't have the dosh :violin:
surenj wrote:I am however concerned about the noise in these? I assume that's the JPG conversion?
Pretty sure it's from the conversion. (I think I may have oversharpened a couple as well) They were converted in DPP (apparently the worst converter for the 7D) and I didn't do any NR. Once the season is over I plan to go back and find the best shots and run full PP and NR over them.
These were done in a few modes as I was playing around. I found the best (most keepers) was using centre point expanded and AI Servo mode. Even doing that the keeper rate is not good. As Matt said - even with practice it's really tough to nail the focus on such fast moving objects.
biggerry wrote:I am interested in your focusing technique, do you have consistent focus during these games?
I use the AF-ON button to aquire focus and the shutter to take the shot. The players are all over the place so it's pretty hit-and-miss.
dviv
Postby surenj on Thu Jun 24, 2010 10:52 am
dviv wrote:Once the season is over I plan to go back and find the best shots and run full PP and NR over them.
Would like to see those results. Hopefully you can use the latest adobe camera raw.
50 1.4 is not the fastest focusing lens though? How does the Tammy 17-50 do in those situations?
Postby dviv on Thu Jun 24, 2010 11:02 am
surenj wrote:50 1.4 is not the fastest focusing lens though? How does the Tammy 17-50 do in those situations?
Haven't tried it - I wanted to use F/1.8 so the Tammy doesn't cut it.
I might give it a go on Sunday for a quarter to see how it goes. I'm hoping the light in Acer Arena is a bit brighter than the state sports centre (where all the other games were located) so 2.8 won't be as much of a problem.
dviv
Postby zafra52 on Thu Jun 24, 2010 6:23 pm
Thanks for the information. Despite some noticeable grain in them that
I attributed to a higher ISO, I don't find it unattractive and besides I
thought you wouldn't be allow to use flash in sporting events and specially
at such close range. Very well done!
