German foggy morning
Postby PiroStitch on Sun Oct 02, 2011 8:29 am
This was captured in the wee morning while driving around the German countryside. The aim was to capture the alps with the rolling fog and the farmhouse to give it some scale and perspective.
I have a few nagging thoughts about this image but wanted to get some objective critique and feedback first before I pointed them out :)
Re: German foggy morning
Postby Reschsmooth on Sun Oct 02, 2011 9:23 am
You know, it's odd: this is fantastic but then I think it is missing something. On the one hand, I think the dark elements are too dark but then I don't think more exposure will add to it. I thnk perhaps a crop from the sides. I think I will conclude that I love it.
Our mug is smug
Postby surenj on Sun Oct 02, 2011 9:42 am
Wow very unique fog around the hut!
Perhaps try to crop 10% from below to strengthen the composition to thirds. Also need to pull detail from the upperleft and perhaps consider pulling some shadow detail from the hills etc. PErsonal preference is for the fog to be pretty white rather than gray/
Chris, did you shoot raw? Can't see the exif.
hope this helps.
Postby zafra52 on Sun Oct 02, 2011 10:08 am
If you cut it too much top and bottom, it will loose
its appeal. Part of its attraction is the contrast between
the dark and light parts, but I agree you need to light
up a bit some of the dark sides to reveal some details.
Postby Mr Darcy on Sun Oct 02, 2011 11:08 am
I'd be inclined to crop a little from the bottom only That dark expanse at the bottom of the photo doesn't do much for me. It needs some to anchor the photo, but not as much as is there.
I would also be inclined to increase the Fill Light (LR3) setting just a little to bring out some detail in the mountains. But without trying it, this may affect other elements of the picture to its overall detriment. (i.e. try it, but be prepared to throw the change away if it doesn't work.
Postby aim54x on Sun Oct 02, 2011 11:16 am
I would definitely crop a bit off the bottom. I think there i a lot of empty space in this image that leaves you looking and searching.
Postby gstark on Sun Oct 02, 2011 11:22 am
Mr Darcy wrote:I'd be inclined to crop a little from the bottom only That dark expanse at the bottom of the photo doesn't do much for me. It needs some to anchor the photo, but not as much as is there.
Exactly.
Postby Geoff M on Sun Oct 02, 2011 11:36 am
I hate to follow like a sheep but I have to agree with the crop from the bottom amd a lift of the shadows.
I would be interested in seeing the colour version too.
http://gmarshall.zenfolio.com
http://xtographer.weebly.com
Geoff M
Postby Mr Darcy on Sun Oct 02, 2011 11:37 am
Here is a quick edit. I have chopped a little off the bottom. May still need more. I have increased fill light overall, then backed off the exposure in the sky to compensate. My apologies for the extra copyright. It is part of my default export action & I forgot to turn it off.
As usual, let me know if you want the photo removed.
Also, you are putting photos at 800 wide. While the rules state this as the maximum, I and others find that you get a better result posting a little smaller. Say 750. I think the auto resize cuts in at 800 and while it doesn't change the size, it does change the quality.
Postby Reschsmooth on Sun Oct 02, 2011 1:00 pm
I like the crop but I think the fill light takes away from the fog.
Our mug is smug
Postby gstark on Sun Oct 02, 2011 2:59 pm
I don't think the fill is needed here, and I'd be even a little more intrusive with the cut. I'd be inclined to just have a sliver of the dark foreground below the farmhouse. At a rough guess, I'd only leave about 30% of what Greg's got in his crop.
Postby PiroStitch on Sun Oct 02, 2011 9:08 pm
Reworked it slightly and added more contrast to certain areas around the image. I've cropped it down to a 2:1 ratio.
Really appreciate the feedback everyone.
Postby Geoff M on Sun Oct 02, 2011 9:55 pm
Much more impact, great atmosphere. Lifting the shadows has revealed just enough detail to add further interest and the crop works so much better.
So what were your nagging thoughts about the image?
Geoff M
Postby Wink on Sun Oct 02, 2011 10:03 pm
I like what Greg's done to bring out more detail in the hills.
Adam.
MY PHOTOS
Allows Image Editing
Wink
Postby gstark on Sun Oct 02, 2011 11:11 pm
Yes. That's much better.
Postby striking on Mon Oct 03, 2011 12:29 am
Great Shot!
I love the contrast - it just goes to show, not everything needs colour and vibrance to be a great image.
striking
Postby CraigVTR on Mon Oct 03, 2011 8:45 am
Love the flow of the mist and the composition, but prefer a point of crop between the original and the last version. However, my eye does get drawn to the light area of sky in the top left and the jet trail.
I do love the mood it conveys.
Craig
CraigVTR
Postby PiroStitch on Mon Oct 03, 2011 5:37 pm
@Geoff - the nagging thoughts I had about the image were the bottom edges (which is what others have mentioned) and the fog trail and house. I wanted the latter two to be more white in order to cut through the entire image, bringing about an abstractness to the image. When I took this image, all I envisioned were the patterns from the clouds and the fog.
There was another part of the image which had the fog enveloping and circling a group of pine trees, which I think the details will only appear as a very large print. Initially I had brought it out (not published online) but then it didn't do much for me at that point. I may revisit this again in the future.
Postby Matt. K on Mon Oct 03, 2011 6:32 pm
A bloody remarkable image! I like your cropped version....but both versions are valid. Pop that image into your 'Fine Art' folder.
Postby PiroStitch on Mon Oct 03, 2011 6:45 pm
I think I just adopted a moniker. I hereby decree my moniker as Chris.
Postby Murray Foote on Mon Oct 03, 2011 9:30 pm
I was thinking along quite different lines.
I think the main subject is the fog and the house but the bright sky distracts from it too much. Maybe make the sky darker but not too contrasty so perhaps include an element of grey sandwich rather than just darkening. May be tricky to get right. The fog could also be a touch lighter as well.
Another option may be to crop down below the sky line and up almost to the shore line, then adjust tonalities to suit.
Murray Foote
Postby biggerry on Mon Oct 03, 2011 9:45 pm
PiroStitch wrote:Reworked it slightly and added more contrast to certain areas around the image. I've cropped it down to a 2:1 ratio.
2.5 thumbs up ;)
very nice image.
