Melbourne by Day
Melbourne by Day
Postby Chaase on Thu Oct 20, 2011 10:34 pm
Some more from the weekend.
Cheers, Bruce
Edit photos OK.
Chaase
Re: Melbourn by Day
Postby Remorhaz on Thu Oct 20, 2011 11:03 pm
The first is very cool and the second is not bad either.
With the first I think it could be warmed some - it looks a little cool to me.
Re: Melbourne by Day
Postby Chaase on Fri Oct 21, 2011 7:37 am
Remorhaz wrote:The first is very cool and the second is not bad either.
Thank you, I have warmed it up.
Cheers, Bruce
Edit photos OK.
Chaase
Re: Melbourn by Day
Postby zafra52 on Sat Oct 22, 2011 4:50 pm
Yes, I think I like the first and second too.
Were you using filters? I feel the colours
should havebeen more vivid in daylight.
Re: Melbourn by Day
Postby tjs001 on Sat Oct 22, 2011 10:03 pm
He means 'Melbourne', by the way. :P
tjs001
Re: Melbourn by Day
Postby Reschsmooth on Sun Oct 23, 2011 9:20 am
tjs001 wrote:He means 'Melbourne', by the way. :P
The forum thanks you. :roll:
Our mug is smug
Re: Melbourn by Day
Postby Chaase on Sun Oct 23, 2011 9:50 am
zafra52 wrote:Were you using filters? I feel the colours
I only used a polariser, the pictures are a bit deceiving as it was overcast most of the time with scattered showers when all the day Yarra ones were taken (kept having to shelter under the bridge) For #2 it had been raining only 2 minutes before (we were sheltering under the bridge on which it was taken on) BTW Melbourne corrected :)
Cheers, Bruce
Edit photos OK.
Chaase
Re: Melbourn by Day
Postby gstark on Sun Oct 23, 2011 11:02 am
Chaase wrote: the pictures are a bit deceiving as it was overcast most of the time with scattered showers
Which part of "it was raining in Melbourne" do you think is a bit deceiving?
:biglaugh: :biglaugh: :biglaugh:
:rotfl2: :rotfl2: :rotfl2:
Sorry.
No I'm not.
Postby Mr Darcy on Sun Oct 23, 2011 12:20 pm
gstark wrote:Which part of "it was raining in Melbourne" do you think is a bit deceiving?
That would be the bit where he said scattered showers
Postby zafra52 on Sun Oct 23, 2011 1:54 pm
Chaase, I hope I am not offending you with this but just using
the Auto tone in CS5 has improved the colours of your
image giving them a bit of vibrancy... I am sure you can do
even better with the original photograph.
pLease let me know if you want to remove your picture. :)
Postby Chaase on Sun Oct 23, 2011 3:21 pm
zafra52 wrote:Chaase, I hope I am not offending you with this
No not at all, it's why I have "Edit photos OK" in my sig. It's the best way to learn
zafra52 wrote:the Auto tone in CS5 has improved the colours of your
I did not even know that feature existed, I will have aplay this evening.
Cheers, Bruce
Edit photos OK.
Chaase
Postby zafra52 on Sun Oct 23, 2011 8:32 pm
Drop down the Image menu to find:
Auto tone
Auto contrast
Auto color
After appliying one of the above, you
can reduce de effect by dropping the
Edit menu and finding the Auto...
whatever effect you last applied.
It is very unsophisticate, but a very
simple way to improve some images.
Postby surenj on Mon Oct 24, 2011 8:46 pm
Zafras edit has brought out the colors. Almost post card esque. Nice compo as well.
