Testing the 17-35mm - IR
Postby aim54x on Thu Mar 29, 2012 8:01 pm
With sunny conditions, an itch to test some more lenses and amazingly a bit of time off work I managed to get out and shoot some IR today. Nothing too flash, just an outing to Mrs Macquaries Chair.
I started off in the CBD, this seemed more of a monochrome image...
As I moved away from the buildings and into the greenery....some false colour trickery seemed to be fitting
I can now happily add that the AF-S 17-35mm f/2.8 is a fine infrared lens (at least for my camera) I couldnt get this lens to hotspot, and it was difficult to get this lens to flare.
Postby chrisk on Thu Mar 29, 2012 9:06 pm
They look fantastic cam. Very nice wb choice. Care to share your wb and pp workflow.
chrisk
Re: Testing the 17-35mm - IR
Postby surenj on Fri Mar 30, 2012 1:39 am
#4 has nice composition Cam. Print it after you clone those buildings out! Perhaps Metallic?? I wonder how that would turn out.
Postby Remorhaz on Fri Mar 30, 2012 8:21 am
Yep that last one is very nice (the last two in fact) - so is this your IR D70?
Postby aim54x on Fri Mar 30, 2012 8:02 pm
Rooz wrote:They look fantastic cam. Very nice wb choice. Care to share your wb and pp workflow.
White Balance was a custom preset I took ages ago...it worked well so I havent changed it since, it can be hard at times to find a nice green patch of grass in full sun!
Workflow is as follows:
-take photo (RAW, Custom WB, standard colour mode)
-open in CNX2
-adjust exposure (Quick Fix -> Exposure Compensation)
-adjust hue (LCH -> Hue -> 180 deg -> drag all the way up) this is the equivalent of a Red/Blue channel swap
-D-Lighting (if applicable)
-adjust contrast (if applicable)
NOTE: if I decide to go to a monochrome image I will not bother to adjust hue (channel swap) and then do the conversion after I have adjusted exposure/d-lighting/contrast
Postby aim54x on Fri Mar 30, 2012 8:04 pm
surenj wrote:#4 has nice composition Cam. Print it after you clone those buildings out! Perhaps Metallic?? I wonder how that would turn out.
Thanks Suren....metallic print would be interesting.
Remorhaz wrote:Yep that last one is very nice (the last two in fact) - so is this your IR D70?
Thanks Rodney. Yes these are from my D80 IR (720nm), it is the only Nikon I own that is sensitive to IR enough to be useful, although I am yet to test the J1 (not holding my breath)
Postby photomarcs on Sat Mar 31, 2012 9:26 pm
awesome stuff man!
Loving the blue hues and the white tones.
Don't be so negative!
http://www.photomarcs.com
photomarcs
Postby zafra52 on Sun Apr 01, 2012 10:42 am
They are all very nice images, but I believe
the second is the best. It works better
than the others for me.
