Red and Mauve (Focus Stacking IV)...
Postby Remorhaz on Sun Aug 12, 2012 4:52 pm
After showing some of my focus stacked images to a few of my work colleagues they decided we should all go out shooting together in the Botanic Gardens one lunchtime.
Early on in the day it was looking good with overcast skies and relatively still conditions - by the time lunchtime arrived however it was clear blue skies and a little windy :)
About half a dozen of us headed across to the gardens with our cameras and gear and looked for suitable subjects - for this trip I borrowed a friends AF-S VR Micro-Nikkor 105mm f/2.8G IF-ED lens (essentially because the front doesn't extend with focus). I was still looking for subjects to focus stack - here are some early samples...
The stacked image of this tulip using 12 of the 19 frames I took [1/160 sec at f/3.2, ISO 640] (again wind was a factor here with the stem swaying in the light breeze - still the software has done a remarkable job of auto aligning the subject for me)
and here is one of the individual frames for comparison
I'm really surprised this next one turned out at all - this stem was swaying around quite considerably and I had little hope of it stacking at all - however both sets of images I stacked worked - here this is the stack of 19 images [1/160 sec at f/4, ISO 1000]
and for comparison a single frame at 1/15 sec at f/11, ISO 800
One further tip I have with focus stacking is this - I stack the images to produce the result with a much sharper main subject with vastly increased depth of field but I then generally blend back in the softer and smoother background bokeh from one or more of the source images (often the nearest focused frame). Sometimes the stacking process produces a slightly ugly background which is mostly a reasonably soft blur but some edges can get enhanced/sort of sharpened by the process. Basically the buttery soft bokeh background from the source frames are generally much nicer.
Re: Red and Mauve (Focus Stacking IV)...
Postby surenj on Wed Aug 15, 2012 2:20 am
Thanks for these Rodney. Very nice results.
Do you blend the background with a mask? [ie manual]
Postby Remorhaz on Wed Aug 15, 2012 12:07 pm
surenj wrote:Thanks for these Rodney. Very nice results.
Kinda yes. In Helicon Focus after the stacking there's a retouch tab where it shows two images (the stacked one plus one of the originals) - you select any original image (and you can paint in bits from multiple originals) and you can make some simplistic brush adjustments (size, feather, etc) and paint back in. It's not anywhere near as featured as doing it with layers in photoshop (where you can make (edge) selections, adjust brush density with pen pressure, alter mask opacity after the fact, etc). I've just done the quick quick and dirty on mine but it seems to mostly do the job (not sure I have the patience for a proper multi hour cleanup in PS :)).
