Middle Head Sunset Telephoto Panorama...
Postby Remorhaz on Tue Apr 02, 2013 7:47 pm
The result of stitching twenty two (22) vertical/portrait frames shot at 85mm 0.8 sec @ f/11 and ISO 100. The field of view is probably a bit over 180 degrees and the resultant image was stupidly large (around 55 thousand pixels wide and almost 8GB in filesize) so I downsized to a 17 thousand pixel wide master to work on instead.
Sunset over the Fort
This really is an image you have to see larger to appreciate (you can click through for a somewhat larger version) and it's surprising just how much very fine detail remains even in my downsized master version when you zoom into the image, also shows you just how sharp this Sigma 85/1.4 is. The following is a very small section of 100% image crop about 1/8th of the way in from the left side.
Postby chrisk on Tue Apr 02, 2013 11:05 pm
I can only imagine how stunning that looks in big size. It's just a beautiful image...epic....gorgeous...
A fair amount of haloing around the trees from that crop though either from sharpening or some other PP work.
chrisk
Re: Middle Head Sunset Telephoto Panorama...
Postby aim54x on Wed Apr 03, 2013 11:38 am
lovely detail, yes there are some halo's.....wonder where they are coming from
Postby Remorhaz on Wed Apr 03, 2013 11:38 am
Rooz wrote:I can only imagine how stunning that looks in big size. It's just a beautiful image...epic....gorgeous...
Thanks Chris - yep I noticed the haloing too - I took the crop from a fullres jpeg output from lightroom so it will definitely be over sharpened for it's size - the master is sharpened in lightroom for "sensible" output viewing and then the fullres output preset is to sharpen again for printing - I just opened that jpeg up in PS and then took out a crop and saved again.
Postby stubbsy on Thu Apr 04, 2013 6:50 pm
Rodney
That's superb - you MUST have it printed - a computer screen will never do it justice.
Postby zafra52 on Thu Apr 04, 2013 7:14 pm
Yes, that white line over the trees is not good for the picture.
I like the first one.
