Seattle at Night
Seattle at Night
Postby Alpha_7 on Thu Mar 22, 2018 3:08 pm
D800, 24mm, f3.5, 1/13, ISO 200
D800, 24mm, f11, 10 sec, ISO 50
D800, 95mm, f9, 10 sec, ISO 100
Re: Seattle at Night
Postby ozimax on Fri Mar 23, 2018 6:50 am
Where did you take these from? A blimp? Drone? Parachuting?
Postby gstark on Fri Mar 23, 2018 7:16 am
ozimax wrote:Where did you take these from? A blimp? Drone? Parachuting?
If the third of these is anything to go by, it clearly wasn't the Space Needle.
Postby gstark on Fri Mar 23, 2018 7:19 am
And it's also not from an incoming aircraft. The wake from the boat in the first image is not in the second, which I expect would be there in that case. Also, SEATAC is some way out of the city.
10 seconds exposure ....
Postby Alpha_7 on Fri Mar 23, 2018 10:02 am
So we did a bit of research and found the Sky View Observatory Columbia Center, so this building is 74 floors high and built on the hill in Downtown Seattle. Its on 4th ave between Cherry and Columbia, on the 73 floor they have build a tourist observation floor with 360 degree views, at a much cheaper price then the space needle. The awesome thing is tripods are welcome, you buy a ticket (cheaper if your a student, which you don't have to prove if you get the friendly ticket collector we had) the ticket is good for 24hrs, so you can keep coming back at different times of day. So we visited twice to get daylight then sunset into dusk. Building is also setup with cafes, and bar and obviously a starbucks in the lobby too!
We were both really impressed by the setup, there are seats and lounges and toilets up there plus information on landmarks.
http://skyviewobservatory.com/
Postby gstark on Sat Mar 24, 2018 9:01 am
Looks very interesting. Thanks.
Postby ozimax on Sat Mar 24, 2018 9:19 am
Mate you're an information bureau. I'll definitely keep this in mind. One of my closest friends has his family not far from Seattle. I would like to return and visit the place. Many thanks.
Postby zafra52 on Sun Mar 25, 2018 2:46 pm
They are awesome! I hope a ride on the lift was included in the ticket.
Postby Alpha_7 on Mon Mar 26, 2018 9:46 am
zafra52 wrote:They are awesome! I hope a ride on the lift was included in the ticket.
Yes they were, my legs would of been jelly climbing all those stairs.
