SOS!!!!
SOS!!!!
Postby Ree on Fri May 12, 2006 7:52 pm
:shock: :?: :shock: I shoot my photos in RAW (NEF.)
I am new to photoshop CS2, last week all I had to do was save as...to make the file JPEGs to take the camera shop to get printed...but now for some unknown reason the JPEG extention doesn't come up :?: :?: :shock: :!:
Can anyone tell me what I have done and MORE to the point how I can FIX what I what done :!:
Mayday mayday mayday
Cheers REE :shock:
"If you have time to spare ... go by AIR!"
Ree
Postby stubbsy on Fri May 12, 2006 7:55 pm
You need to change your image to 8 bits. You can't save 16 bit images as jpeg. Go to Image/Mode/8 bits per channel. You can set Adobe Camera Raw to either 8 or 16 as a default. You must have changed it to 16.
Postby Ree on Fri May 12, 2006 8:01 pm
stubbsy Posted: Fri May 12, 2006 9:55 pm Post subject:
:oops: :oops:
Thanks Stubbsy :!: :!: :!: :!: :!:
My way of learning :? is playing around...some times I forget that I have changed a setting and after awhile passes this happens :oops: :oops:
If I ever met you I owe you a hug :!:
Cheers REE :shock:
Ree
Postby leek on Fri May 12, 2006 8:11 pm
Ree,
You can save as TIF format in 16 bit and most print-shops accept that format as well... It might make for a higher quality image...
Cheers, John
leek
Postby Ree on Fri May 12, 2006 8:15 pm
leek Posted: Fri May 12, 2006 10:11 pm Post subject:
Ree,
John,
I am changing over files now to get printed in the morning. I will make a few of them TIF and see how they come out. Thanks for the tip
Cheers REE :shock:
Ree
Postby Nnnnsic on Fri May 12, 2006 9:30 pm
Actually John, I know from some friends who work at various imaging print houses around Sydney that they'll charge extra to convert from a 16-bit file to an 8-bit.
It's ridiculous I know but as a suggestion, I'd convert all your images to 8-bit just in case.
Nnnnsic
Postby Finch on Fri May 12, 2006 9:41 pm
leek wrote:Ree,
Good advice, Leek, except that sometimes the 16bit TIFF files are just too big for the shops to handle (if they aren't pro labs).
Finch
