Eyepiece cap
Eyepiece cap
Postby Alex on Tue May 03, 2005 9:26 pm
When using a tripod, do I need to use the DK-5 eye cap to block stray light entering viewfinder once I press the exposure button and the self-timer is activated? If I half-press the shutter and self-timer starts isn't the exposure setting already fixed regardless of the light entering the viewfinder? (I have half way exposure button press - locked exposure setting activated).
Thanks for any suggestions.
Postby Onyx on Tue May 03, 2005 9:45 pm
I thought the viewfinder cap was to block stray light from interferring with the camera's metered light readings, so you'd set everything up and put the eye cap on before triggering the remote shutter release.
Someone help out us n00bs and tell us definitively what that DK-5 is meant to be used for!
Onyx
Postby MCWB on Tue May 03, 2005 10:46 pm
Alex: even though the exposure settings are fixed, if stray light comes in and hits the sensor it will throw your exposure out. I'd imagine if you shone a torch into the viewfinder for example your image might come out a tad overexposed. :)
MCWB
Postby joolz on Wed May 04, 2005 12:17 am
I've had incidences where stray light coming from the viewfinder caused flare like artifacts on my image when I triggered remote. I've since learnt to use the cap when I can. I guess it is particularly prone if there is strong ambient or direct light coming from behind the camera.
Joolz
joolz
Postby gstark on Wed May 04, 2005 7:14 am
MCWB wrote:Alex: even though the exposure settings are fixed, if stray light comes in and hits the sensor it will throw your exposure out. I'd imagine if you shone a torch into the viewfinder for example your image might come out a tad overexposed. :)
Actually, that would cause underexposure.
Onyx, Alex, yes, you should use it, placing it on the viewfinder prior to releasing the shutter.
Postby MCWB on Wed May 04, 2005 8:34 am
gstark wrote:Actually, that would cause underexposure.
Maybe I wasn't clear, I wasn't talking about shining the torch in during the exposure, such that more light than intended hit the sensor. You're right though, doing it whilst metering but not exposing would cause underexposure.
MCWB
Postby Alex on Wed May 04, 2005 8:48 pm
Thanks for clarifying it, everybody. Still if I did the reading while looking through the viewfinder then locked the exposure settings with AE-L button and then pressued the exposure button would using the cap be benefitial? Just seems a pain to take the rubber eye piece on and off everytime when using tripod like a bit of a pain.
Postby digitor on Wed May 04, 2005 9:04 pm
Taking the rubber surround off is a pain - a piece of black tape is easier to use! Doesn't need to be stuck too hard - just sitting there, and it doesn't really matter if you lose it.
digitor
Postby nito on Sun May 15, 2005 11:54 pm
digitor wrote:Taking the rubber surround off is a pain - a piece of black tape is easier to use! Doesn't need to be stuck too hard - just sitting there, and it doesn't really matter if you lose it.
Ahhhh so thats how you fit it on! :o After all this time, I thought it was a useless piece of plastic which adds 30c to the purchase price of my D70. :?
nito
Postby Andyt on Mon May 16, 2005 12:01 am
I second Digitor's "taped" view finder, I use the same method, much easier and quicker......... besides with the light being stronger and brighter here in WA its a must :lol: :wink: :lol:
Andyt
Andyt
Postby sirhc55 on Mon May 16, 2005 12:03 am
I just drape a very light glasses cleaning clothe over the viewfinder - stops sticky rubber :D
Postby shockadelica- on Thu Jun 16, 2005 6:03 am
i cup my hand and place it over the viewfinder
but theres a smarter idea!! the cleaning cloth
or if the cleaning cloth is too thin a small square of black demin would be great
i might do that if i remember next time im near a spotlight store
shockadelica-
Postby gstark on Thu Jun 16, 2005 7:15 am
Whatever method you choose, be aware that you should be clear of the camera - not actually touching it - during or just prior to the moment(s) of exposure, in case you induce movement or vibration.
That is what's known as not a good idea. :)
