Dust on sensorModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Dust on sensorI try to read about cleaning , but to start to tell about my
ignorance I do not even know where the sensor is... Well can you explain in detail for a total novice? I have a dust on the top middle left of all images and psd is a bit tiring after a while! thanks Regards Haydee
Haydef,
For detailed instructions on wet sensor cleaning try this link: http://www.pbase.com/copperhill/ccd_cleaning First thing however would be to try removing it with a blower. The Giotto Rocket (the large one) is what most would reccomend. Also, if you add your location to your profile, I am certain that you will find someone to show you if you are not confident with sticking things into the chamber. Cheers Matt
Re: Dust on sensor
Welcome Haydee, Pls. have your location in your profile so members can help you more easier if you're around Australia or just nearby one of the mini meets. Birddog114
To locate (and clean) the sensor, you need to first of all make sure that your battery is fully charged. You (obviously ) should be working in a relatively clean, dust free environment.
Turn your camera off and remove the lens. Turn the camera on. Looking at the back of the camera, select the menu, and select the "Mirror Lock Up" option from the menu. Turn the camera towards you. You will see, towards the rear of the interior of the camera, a rectangular flat sction. That is your sensor. Please refer to the link provided above for cleaning the sensor. g.
Gary, Good advice. The only correction I would make is never to turn your cammera on with lens off unless mirror is locked up. Once you remove lens with the camera on the sensor is known for attracting dust particles. In mirror lock up mode it doesn't seem to be an issue. So my version would be to: 1. Lock up mirror 2. Remove lens 3. Clean 4. Switch off (puts mirror back in normal position) 5. Lens back on 4 and 5 can be reversed. Alex
Alex,
No, not really. Under normal circumstances, with the lens removed from the camera, the sensor remains protected by the focal plane shutter as well as the mirror. If you rem,ove your lens and carefully lift the mirror a little way, you can actually see the shutter in place, in front of and totally obscuring the sensor, just as a shutter fully obscures the film in a film camera. Further, that "attraction" that you're referring to as a result of the "charging" of the CCD in order to capture the exposure. Thus causes a build-up of a static electricityin the CCD, thus creating the "attraction" that you're referring to. Normally, the CCD is uncharged, and thus this "attraction" is not present. Further, the actual question I was answering was one of how to locate the sensor - as in where is it - rather than how to clean it. g.
Gary, Thanks for the info. Good to know then. Alex
Return to Absolute Beginners Questions Who is onlineUsers browsing this forum: No registered users and 12 guests |
