Foreign bought Nikon Quick Charger MH-23 work in Aus?
Postby markjd on Sun Jul 01, 2007 12:25 pm
I am looking at buying a Nikon D40 from Japan. Will the Quick Charger MH-23 work here in Aus?
Mark
markjd
Postby gstark on Sun Jul 01, 2007 12:47 pm
That might depend upon from whom you bought it. Who are you thinking of buying from?
My D200, bought from Poon, has a charger that works with no problems.
Postby markjd on Sun Jul 01, 2007 12:59 pm
gstark wrote:That might depend upon from whom you bought it. Who are you thinking of buying from?
I am thinking of buying from a discount Japanese site. Price is pretty good. I don't know Poon's prices.
With your charger, does it plug directly into the power socket, or is there a power cable?
markjd
Postby gstark on Sun Jul 01, 2007 1:17 pm
Standard 2 core figure-8 cable used by just about everything.
What are the input specs for the charger in question? That will give you a definitive answer to your questions.
Why would you be buyiong from Japan? Unless you're physically located there, HK is usually cheaper. Do you know and trust the Vendor?
Postby Ivanerrol on Sun Jul 01, 2007 1:22 pm
Your power cord will require an Unique Aussie 240v plug to be installed on it.
Ivanerrol
Postby markjd on Sun Jul 01, 2007 3:31 pm
gstark wrote:Standard 2 core figure-8 cable used by just about everything.
I don't know the input specs for the charger. I've since seen an image of the charger and see it has some fig 8 cable.
The reason I am looking at sourcing the camera from a particular Japanese site is their price: under $600 with kit lens and delivery inc. That's the cheapest I've seen, including HK ebayers. The vendor has been around for a few years, so I kinda I trust them :)
markjd
Postby Yi-P on Sun Jul 01, 2007 7:19 pm
If the charger is genuine, it should work with a range of 100-240V. There is very little reason for Nikon to put their charger for a travelling device to work under certain fixed voltage, and that is really stupid if they do.
Postby big pix on Sun Jul 01, 2007 8:41 pm
Brought a D70s from the US a while back..... just took the charger into Tandy and brought a new lead with an Aus plug, as it should be seperate from the charger...... only cost a few dollars
happy for the comments, but
big pix
Postby markjd on Mon Jul 02, 2007 10:02 am
big pix wrote:Brought a D70s from the US a while back..... just took the charger into Tandy and brought a new lead with an Aus plug, as it should be seperate from the charger...... only cost a few dollars
Thanks. I'll check them out when I get the camera.
markjd
Return to Nikon
