D70 not 'detecting' lenses
Postby Hyena on Mon Sep 10, 2007 11:35 am
Hey guys,
My D70 has started playing up recently, when you connect a lens the F just flashes like there's no lens connected. I went up to Qld last week and put it inside my checked luggage, but it was inside a well padded lowepro bagged, wrapped in clothes and then inside the suitcase. It was working fine for my kit and zoom lenses but when I swapped for my 50mm it started playing up. At first I thought it was a problem with the 50mm and went back to using the other 2 but after getting home it now does it with all my lenses, leading me to think it's more likely to be a fault with the camera.
Anyone come across this problem before ?
Is there anything I can try before taking it off to get looked at ? The contacts in the camera look clean.
Jay
Jay
Nikon D70 | 18-70mm F3.5-4.5 | 50mm F1.8 | Tamron 70-300mm F4-5.6
Hyena
Postby gstark on Mon Sep 10, 2007 1:07 pm
Didja set the lens to maximum aperture? This is expected behaviour when the lens isn't correctly set.
Postby big pix on Mon Sep 10, 2007 1:10 pm
gstark wrote:Didja set the lens to maximum aperture? This is expected behaviour when the lens isn't correctly set.
yep...... and a clean of the contacts would also be good......
happy for the comments, but
big pix
Postby Hyena on Mon Sep 10, 2007 1:15 pm
Yes, this is the first thing I thought too considering it started doing it with my 50mm which I often reverse, but the other 2 lenses do it as well and I hadn't touched anything other than flicking from auto to manual focus.
I'll try cleaning the contacts (metho on a cotton bud ? ) but they already look nice and clean... :?
Jay
Hyena
Postby bwhinnen on Mon Sep 10, 2007 1:23 pm
Buy some contact cleaner, metho leaves a residue...
bwhinnen
Postby Hyena on Wed Sep 26, 2007 11:22 am
For future reference if anyone has any similar problems - I sent it off for repair - turned out it was the lens contact unit that packed it in.
$2.69 part, $120 labour :roll:
Ah well, could have been worse. Back to shooting now :)
Jay
Hyena
Postby stubbsy on Wed Sep 26, 2007 8:36 pm
Thanks for the update and advice Jay.
Return to Nikon
