ProPhoto RGB
Re: ProPhoto RGB
Postby aim54x on Wed May 19, 2010 10:05 pm
I can kind of see a difference (sorry 10" screen makes direct comparison difficult, I will have to have another look on another screen later). Huge thanks Bob for sharing your findings!
Re: ProPhoto RGB
Postby Murray Foote on Wed May 19, 2010 10:21 pm
I have two profiled monitors, one sRGB and one aRGB and I don't see much difference on either. If anything I prefer the aRGB version where the yellow on the fence post is a bit brighter and the colour contrast on the wire seems a bit higher.
Regards,
Murray
Murray Foote
Re: ProPhoto RGB
Postby BullcreekBob on Wed May 19, 2010 11:36 pm
Murray Foote wrote:I have two profiled monitors, one sRGB and one aRGB and I don't see much difference on either. If anything I prefer the aRGB version where the yellow on the fence post is a bit brighter and the colour contrast on the wire seems a bit higher.
Regards,
Murray
This is interesting. Both images contain an embedded profile and your monitors and o/s should perform correct colour management which means in a correctly colour managed workflow that image #1 should look the same on both screens and image #2 should look the same on both screens.
What software are you using to view the images? Don't forget that IE is not colour space aware and "assumes" sRGB but nevertheless both images ARE in sRGB so it MIGHT be that the colour mapping for your Adobe RGB monitor has been incorrectly setup or your OS (or hardware) is not correctly colour mapping to it.
Bob
Bob in sunny Perth
What gear? Watch this space!
BullcreekBob
Location: Manning - an inner southern suburb of Perth, WA
Re: ProPhoto RGB
Postby Murray Foote on Thu May 20, 2010 12:29 am
I'm viewing them on Firefox. I didn't say they look different between screens, I was comparing the two images on either screen.
Regards,
Murray
Murray Foote
Re: ProPhoto RGB
Postby surenj on Thu May 20, 2010 9:40 am
Can a program display two different images from two different color spaces accurately on the SAME screen?? :shock: I didn't think this was possible?
Re: ProPhoto RGB
Postby BullcreekBob on Thu May 20, 2010 12:54 pm
surenj wrote:Can a program display two different images from two different color spaces accurately on the SAME screen?? :shock: I didn't think this was possible?
Any program that is correctly colour managed can do this. The main processes involved in colour management is to be aware of the colour profile used by (or embedded within) an image and to convert it to the colour profile used by whatever display or print device the image is being viewed or printed on.
However, that was not the situation with the two images I posted. They were both sRGB images the only difference between then was the editing was done using different colour spaces. One was edited in sRGB the other had the exact same editing steps but performed using the Prophoto colour space. But both jpgs were sRGB.
Bob in sunny Perth
BullcreekBob
Re: ProPhoto RGB
Postby Murray Foote on Thu May 20, 2010 11:39 pm
It is as long as they are both within the colour space the screen is profiled for.
Regards,
Murray
Murray Foote
Previous
Return to Post Processing
