Nikon Veiw Any users??
Postby BBJ on Sat Feb 18, 2006 11:36 pm
Hi All, well i usually use Nikon Veiw to resize my pictures for the web and for some reason it works but the output to the folder ends up with hoting but a 0kb file in it. So i have uninstalled and reinstallen and even dwnoaded new version and still no go.
So how can i batch process to resize all my pics in 1 hit, have had a look in PS but not sure if it will do this, any hint on other proggies or how to fix my problem??
Thanks
John
BBJ
http://www.oz-images.com
BBJ
Postby leek on Sun Feb 19, 2006 12:00 am
Which version of Photoshop are you using John?
If it's the latest, then you might want to give Tools-->Photoshop-->Image Processor a try - that'll do what you want...
If you're using the last version, then you can download the Image Processor as a plug-in from russellbrown.com
Cheers, John
leek
Postby BBJ on Sun Feb 19, 2006 12:13 am
Hi John, well i have both CS and CS2 and wlel just looked for tools etc in CS2 and well i will have another look, as cant seem to see it.
BBJ
Postby BBJ on Sun Feb 19, 2006 12:39 am
Ok John thanks i found it had to go to bridgem still not up with all this as yet so yeh thanks and all done.
John
BBJ
Postby leek on Sun Feb 19, 2006 6:54 am
Yep... Select all the images you want to convert in Bridge and then run the Image Processor... If you go into the Raw Converter for each image first, you can adjust the exposure, sharpening and other settings first and the Image Processor will take this into account when converting... You may still need to sharpen the final images though.
Cheers, John
leek
Postby BBJ on Sun Feb 19, 2006 9:37 pm
Thanks John, Now tell me when i have tried to open a RAW file and it opens PS CS2 it comes with unsupported file, or is there a special RAW plug in or something. Thanks mate for the help.
John
BBJ
Postby leek on Sun Feb 19, 2006 9:52 pm
BBJ wrote:Thanks John, Now tell me when i have tried to open a RAW file and it opens PS CS2 it comes with unsupported file, or is there a special RAW plug in or something. Thanks mate for the help.
John
If you installed CS2 from a standard disk, then Adobe Camera Raw should be included as standard... If not, then you can download it from here: http://www.adobe.com/products/photoshop/cameraraw.html
You will need to save it in the File Fomats folder which is buried somewhere deep in the Adobe folder...
Cheers, John
leek
Postby BBJ on Sun Feb 19, 2006 10:53 pm
Thanks again John, works a treat. Git the RAW plugin and all up and running so thats good not that i would always use this, but maybe i will instead on Nikon Capture now.
John
BBJ
