Lens not fitting???
Lens not fitting???
Postby PlatinumWeaver on Fri Mar 31, 2006 12:46 pm
Hey,
I just picked up a 50mm f/1.8 lens for my Nikon... and it doesn't fit my D70.
It seems way too tight, it seems to fit with the left side of the camera ( non-handgrip side ), but loots almost like it is tilted because it doesn't sink as far into the camera on the right side.
Does any of this make sense?
Can anyone help?
<-- starting to panic.
PlatinumWeaver / Dean
Asking the Stupid Questions
<a href="http://www.platinumweaver.net/" alt="PlatinumWeaver Homepage">http://www.platinumweaver.net/</a>
PlatinumWeaver
Postby MATT on Fri Mar 31, 2006 12:47 pm
Pics???
MATT
Postby Greg B on Fri Mar 31, 2006 12:49 pm
Dean, does the lens look OK? Not warped or anything peculiar like that?
Greg - - - - D200 etc
- Arthur Schopenhauer
Greg B
Postby PlatinumWeaver on Fri Mar 31, 2006 12:49 pm
No other camera here at the moment, so I cant take pictures...
PlatinumWeaver
Postby PlatinumWeaver on Fri Mar 31, 2006 12:53 pm
Looks fine.. doesn't look warped...
Looks exactly like every other 50mm lens i've ever seen...
Have I done something stupid like gotten a nikon lens for a different mount?
PlatinumWeaver
Postby Ivanerrol on Fri Mar 31, 2006 12:55 pm
Where did you get this lens? EBay? Retail? Grey dealer?
Ivanerrol
Postby MATT on Fri Mar 31, 2006 1:02 pm
Can you put another lens on and take apic of the 50 lens mount.
MATT
MATT
Postby gstark on Fri Mar 31, 2006 1:09 pm
Dean,
How old is the lens?
Does it have a small aluminium shoe with a slot in it, adjacent to the numbers on the aperture ring? If so, is their a small hole on each side of this slot, or is it solid?
I'm thinking that it may be a very early, pre-AI mount lens, which would be difficult to mount, and would present in this manner.
Postby PlatinumWeaver on Fri Mar 31, 2006 2:13 pm
Brand Spanking New
PIctures incoming
PlatinumWeaver
Postby PlatinumWeaver on Fri Mar 31, 2006 2:18 pm
okay - now i'm getting a flashing green LED at the back...
This is new....
PlatinumWeaver
Postby PlatinumWeaver on Fri Mar 31, 2006 2:33 pm
Step 1: Take new Nikon 50mm 1.8D lens
Step 2: Line up the dots on D70 Body
Step 3: Try to rotate lens.
Step 4: Encounter Resistance approximately 1/8 of the way around. Stop.
Step 5: Tentatively test resistance
Step 6: Stop. Try to take an image to see if that works.
Step 7: Remove lens, examine, scratch head.
Step 8: Try again.
Step 9: Post to Forums.
Step 10: Try to take shot of new lens with Kit lens.
Step 11: LED of Death.
Now with no lens on at all I can switch the camera on fine and access the menu, navigate like normal. With a lens in, any lens, the menus flash up then die, LED flashes.
So... who's the recommened nikon repairer in Melbourne?
PlatinumWeaver
Postby losfp on Fri Mar 31, 2006 2:38 pm
Urgh.. that doesn't sound good. Have you tried resetting the camera?
http://www.nikondigitutor.com/eng/d70/s ... =b14&num=1
losfp
Postby Glen on Fri Mar 31, 2006 2:39 pm
Dean, take camera and lens to where you bought the lens just in case it is a bad sample
Edit just saw the any lens quote!!
Camera Clinic Address:
56 Easey Street,
Collingwood,
VIC 3066
Phone: (03) 9419 5247
Fax : (03) 9417 7628
Repair & servicing for all Nikon (film-based & digital products), Nikon binoculars, Nikonos underwater equipment and 10% discount on labour for Nikon Club members.
Postby mitedo on Fri Mar 31, 2006 2:39 pm
Sell the lot and go Canon :lol: :lol: like the rest of the crew :wink:
Kevin
mitedo
Postby PlatinumWeaver on Fri Mar 31, 2006 2:45 pm
2-button reset got it to a point where it'll switch on! Thank you!
I think the metering information may be broken though.
Uhh.. scratch that... Camera just locked up entirely. Off/On switch wont even work now, but the menu system is fine.. First symptom was a lack of auto-focus...
PlatinumWeaver
Postby PlatinumWeaver on Fri Mar 31, 2006 2:50 pm
mitedo wrote:Sell the lot and go Canon :lol: :lol: like the rest of the crew :wink:
RDRR
Not too helpful.
PlatinumWeaver
Postby PlatinumWeaver on Fri Mar 31, 2006 2:51 pm
Spoke to repair place... will let you know how it goes.
PlatinumWeaver
